Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457
HDTV.ru > Это интересно > В чем разница между дорогими и дешевыми Blu-ray плеерами?
В чем разница между дорогими и дешевыми Blu-ray плеерами?12.05.2014 |
Blu-Ray-плееры бывают самых разных форм и размеров, с ценниками от нескольких десятков до нескольких сотен тысяч евро. У покупателей в последнее время накопилось немало вопросов о реальных различиях между этими проигрывателями Blu-ray дисков, потому что с точки зрения качества изображения порой достаточно трудно найти разницу между многими доступными и дорогими моделями. В этой статье мы попытается разобраться, почему так происходит. Как вы, наверное, замечали даже по обзорам, реальная разница в качестве изображения и звука между Blu-ray плеерами, например, Panasonic и Samsung, зачастую вряд ли заметна. Большинство производителей очень хорошо освоили реализацию технологий воспроизведения видео, даже в сравнении с такими наиболее дорогими брендами, как Oppo, Marantz и Denon. Но если визуально в качестве изображения нет особых различий, тогда за что же вы платите гораздо больше? Качество сборки Есть ряд ключевых различий между доступными и более дорогими Blu-ray плеерами. Первым обычно упоминается так называемое качество сборки, под которым понимается как качество изготовления отдельных элементов конструкции, так и их сборка. Все это имеет достаточно большое значение для воспроизведения видео и звука. Прочный усиленный корпус сможет предотвратить появление вибраций, что особенно заметно, когда проигрыватель дисков подключен к усилителю с акустическими системами самого высокого класса. Известно, что система настолько хороша, насколько хорошо ее самое слабое звено. Стабильными и надежными должны быть все компоненты с минимальным влиянием на воспроизведение. Очень важно не только качество сборки и жесткость корпуса и подставки. Серьезная нагрузка ложится на лоток для диска, особенно если вы смотрите много фильмов. Качество звука Кроме того, у моделей Blu-ray плееров высокого класса возможности воспроизведения звука, как правило, шире, чем у стандартных моделей. Часто они имеют высококачественный цифро-аналоговый преобразователь, поставляются с аналоговыми 7.1-канальными выходами, используются разъемы с позолоченными выводами. Все эти особенности имеют большое значение для передачи максимально достоверного звука без потери деталей акустической сцены. Многие аудиофилы выбирают Blu-ray плееры только с аналоговыми выходами на 7 каналов с сабвуфером для сохранения «теплого» аналогового звука. ( Хотя, с развитием цифровых интерфейсов это уже предмет отдельного разговора.) Качество изображения Не только по качеству воспроизведения звука, но и по качеству видео могут быть существенные различия между дешевыми и дорогими плеерами. Более дорогие плееры высокого класса часто оснащаются высокопроизводительным видеопроцессором, который дополняется системой видеообработки. Полученный после видеообработки сигнал должен иметь минимум шумов с сохранением четкости мелких деталей. Чем больше экран вашего телевизора, тем более явными могут выглядеть погрешности в работе технологий обработки цифрового видеосигнала. На экране в 60 дюймов вы сможете отметить шум и размытие деталей, которые могут быть незаметны на маленьком экране. В большинстве случаев, плеер с более совершенной системой видеообработки гарантирует, что вы получите оптимальное качество изображения даже на большом экране. Важно также отметить, что лучшие Blu-ray плееры часто выделяются не только более совершенным воспроизведением видеоматериалов стандартного разрешения, преобразуемом до высокого разрешения, но также и возможностями преобразования чересстрочного изображения, которое передается по эфирным телеканалам. Для отображения такого контента в повышенном разрешении требуется специальная предварительная обработка для перевода изображения в обычные построчные кадры. Качество конечного изображения зависит от используемой технологии деинтерлейсинга цифрового сигнала (устранения чересстрочности). Другие особенности Важные различия между дешевыми и дорогими плееры Blu-ray плеерами могут быть и по функциональной оснащенности. Сегодня почти любой плеер поддерживает воспроизведение 3D видео, но функция повышения разрешения выходного сигнала до разрешения 4K является пока новинкой. В случае если у вас есть Ultra HD телевизор, высококачественная система повышения разрешения Blu-ray плеера может оказаться не лишней, даже если за это придется доплатить. Более совершенные процессоры обеспечивают более качественную обработку при повышении разрешения, что особенно заметно на больших экранах. Кроме того, вам часто приходится доплачивать за такие функции, как два выхода HDMI, что может пригодиться, если ваш ресивер не поддерживает передачу сигналов в разрешении 4K или с поддержкой 3D. При необходимости можно подобрать Blu-ray плеер с расширенной поддержкой таких аудио технологий, как форматы звука высокого разрешения, Dolby TrueHD и DTS-HD Master Audio, воспроизведение дисков Super Audio CD, беспроводной прием звука через Bluetooth. Вернуться назад |
