Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457
HDTV.ru > Новости индустрии > 4K ЖК LED телевизор Panasonic VIERA TX-85XR940 скоро в России
4K ЖК LED телевизор Panasonic VIERA TX-85XR940 скоро в России02.12.2014 |
Интеллектуальный дизайн, большое количество функций и высочайшее качество 4K изображения полностью соответствует ожиданиям и радуют взгляд. 85-дюймовый 4K телевизор оставит незабываемые впечатления от просмотра на большом экране, доставит удовольствие самому искушенному владельцу. Телевизор VIERA TX-85XR940 сочетает в себе: Технология студийного мастеринга: Технология студийного мастеринга позволяет добиться плавной градации тонов и недостижимой ранее детализации черного цвета даже в самых темных кадрах. Принцип работы технологии заключается в многократной коррекции изображения и достижении точной цветопередачи при любом уровне яркости. Процессор Quad Core Pro: Четкое и детализированное изображение из любого источника Высокопроизводительная система обработки изображений Panasonic способна без потерь выводить на экран материалы в разрешении 4K. Система оснащена встроенными функциями снижения шумов и компенсации движения, а также поддерживает работу с телетрансляциями, веб-контентом и другими источниками. Технология студийного мастеринга цвета: Высокая яркость и богатая цветовая гамма. Новейшая технология светодиодной подсветки в сочетании со студийным мастерингом цвета расширяют цветовое пространство до значений, покрывающих 98 % стандарта DCI. Расширенное цветовое пространство позволяет воспроизводить естественные цвета и дает зрителю возможность насладиться материалом именно в том виде, в котором он был задуман автором. В первой декаде декабря 2014 года модель VIERA TX-85XR940 будет доступна со склада «Элиттех», официального дистрибутора компании Panasonic. Рекомендованная розничная цена: 849 990р. Технические характеристики VIERA TX-85XR940: • ЖК панель с разрешением 4K со светодиодной подсветкой • Формат 16:9 • Формирование изображения: Сканирующая подсветка 2000 Гц 4K IFC PRO • Режим воспроизведения изображения: «Динамический», «Стандартный», «Кинотеатр», THX 4K («Кинотеатр», «Освещенная комната»), «Монитор», «Пользовательский», «Профессиональный 1», «Профессиональный 2» (isfccc) • Угол обзора: 176 градусов • Технология: Clear Panel • Цветовое пространство: Технология студийного мастеринга цвета • Технология Studio Master Drive • Технология локального затемнения Ultra Local Dimming Pro • Оптимизация контента Content Optimiser Pro • Дисплей отмечен сертификатом THX • 4K/1080p Pure Direct • Режим ISF Вернуться назад |
