Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457
HDTV.ru > Новости индустрии > Телевизоры Samsung H6640: Smart, Edge LED, Micro Dimming Pro, CMR 600
Телевизоры Samsung H6640: Smart, Edge LED, Micro Dimming Pro, CMR 60010.04.2014 |
Телевизоры Samsung H6640 в основном обладают такими же характеристиками, как и модели из серии Samsung H6500. В них представлены технологии Micro Dimming и CMR 600. Помимо этого, мы находим здесь 4-х ядерный процессор, двойной тюнер, функцию картинка-в-картинке под новым названием Multi-Link. Кроме того, обеспечена совместимость с 3D, новый портал Smart Hub 2014, доступ ко всем мультимедийным функциям, подключение к сети, запись видео через порт USB, голосовое управление, и др. Технические характеристики Samsung H6640: • Edge LED 3D 1080p • Micro Dimming Pro • 3D и конверсия 2D/3D • Четырехъядерный процессор • Clear Motion Rate (CMR) 600 • Двойной тюнер • Запись через порт USB, отложенный просмотр, картинка-в-картинке • Интегрированный Wi-Fi с поддержкой DLNA 1.5 • Samsung Smart Hub 2014 с множеством приложений • Smart контент: 1400 приложений, AllShare, AllSharePlay, браузер • Упрощенное отображение видео со смартфона и планшета • Система рекомендаций для просмотра • Воспроизведение через USB и из сети: DivX HD, MKV, TS, AVI, MP4, AAC, MP3, WMV, WMA, ... • Интерфейсы: 4 x HDMI 1.4a (ARC/3D), 3 x USB, 1 x YUV, композитный, VGA, 2 x Scart, аудио вход, Ethernet • В комплекте 3D очки Samsung SSG-5100GB Телевизоры Samsung H6640 появятся в европейских магазинах с апреля 2014 года по следующим ориентировочным ценам: • Samsung UE55H6640: 1499 евро • Samsung UE48H6640: 1099 евро • Samsung UE40H6640: 899 евро. Вернуться назад |
