Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 4K OLED телевизоры Sony и Panasonic
HDTV.ru > Новости индустрии > 4K OLED телевизоры Sony и Panasonic
21.01.2013
На выставке CES 2013 Panasonic и Sony показали 56-дюймовые OLED телевизоры с разрешением 4K. Телевизоры были выполнены на основе совместно разработанной японскими компаниями OLED панели.
4K OLED телевизор Panasonic на выставке CES
56-дюймовый телевизор, соответствуя размерам большой гостиной, все же недостаточно большой, чтобы конкурировать с некоторыми из 4K ЖК телевизоров, которые были представлены на выставке. Panasonic поставил телевизор на металлическую подставку. Очень тонкий корпус был закрыт сзади металлической панелью.
4K OLED-телевизор Panasonic на выставке CES
Качество изображения, несомненно, было впечатляющим. Цвета были невероятно яркие и контрастные. Черные области были как смоль, при этом телевизор был в состоянии воспроизводить очень яркие образы, когда требуется. Были отмечены некоторые отражения (на картинке ниже, вы видите зеленые отражения справа). Углы обзора практически совершенны.
Телевизор имеет разрешение 3840x2160 пикселей и, конечно, обеспечивает невероятный уровень детализации. Впрочем, это уже не столь заметно, если вы отодвигаетесь от экрана более чем на 2,5 метра. 56-дюймовый экран телевизор не достаточен, чтобы полностью оправдать разрешение 4K, по крайней мере, не для гостиной, где зрители сидят в 4-5 метрах от экрана.
4K OLED телевизор Sony
Версия OLED телевизора Sony на стенде компании была больше похожа на опытный образец.
4K OLED телевизор Sony на выставке CES
Sony демонстрировала несколько потрясающих снимков природы и высококонтрастное видео, которые давало понятие о том, насколько глубок черный цвет на экране OLED телевизора. Черная глубина была очень впечатляющей, и это делало изображение ярким и живым. Тем не менее, некоторые из очень темных сцен также выявили проблемы с отражением, как и у Panasonic. На стенде Sony было больше шансов оценить контрастность и глубину черного, которых нет ни у плазм, ни у ЖК LED телевизоров. Немного ближе расположенный экран 4K OLED телевизора Sony позволял по-настоящему оценить впечатляющий уровень детализации 4K экрана.
Samsung и LG нужно пошевеливаться
OLED прототипы Sony и Panasonic на выставке выглядели очень впечатляюще, судя по всему, японские производители готовы конкурировать с Samsung и LG после освоения массового выпуска. Теперь все зависит от того, кто сможет массово с минимальными затратами выпускать OLED панели и снижать издержки. Panasonic и Sony будут производить свои OLED панели печатным методом. Сможет ли эта технология обеспечить преимущество японским производителям над корейскими, покажет уже ближайшее время.
Вернуться назад
