Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Новый монитор ViewSonic VX2460H
HDTV.ru > Новости индустрии > Новый монитор ViewSonic VX2460H
05.05.2012
Компания ViewSonic будет продавать в России новый 24 дюймовый монитор VX2460H из серии VX. Это сверхтонкий монитор с толщиной корпуса всего 6,8 мм, в новом стильном дизайне. Сертификация Energy Star ® 5.1, светодиодная подсветка и режим ECO позволяют экономить до 40% энергии, по сравнению с обычными мониторами. ViewSonic VX2460H обладает сверхбыстрым временем отклика в 2мс, обеспечиваемым применением технологии ClearMotiv ® II, динамическая контрастность составляет 40 000000:1 (при естественной 1000:1). ViewSonic VX2460H поддерживает разрешение Full HD 1080p с соотношением сторон изображения 16:9 и оснащен двумя входами HDMI 1.3. Все это делают VX2460H универсальным выбором для домашнего и офисного использования.
Ожидается, что ViewSonic VX2460H поступит в продажу в Европе в середине мая по рекомендованной розничной цене около €200.
Особенности ViewSonic VX2460H:
Контрастность 1 000:1 (тип.)
Углы обзора 170° / 160° (тип.)
Область отображения 60см (23.6”) широкоформатный
Оптимальное разрешение 1920 x 1080
Время отклика (тип.) Тип. 5мс / G to G 2мс
Поверхность панели антибликовая, с защитой от царапин
Шаг пиксела 0.2715 мм x 0.2715 мм
Яркость 250 кд/м²
Коэффициент динамической контрастности 40 000000:1
Подсветка White-light LED
Срок службы подсветки 40 000 часов (мин.)
Вернуться назад
