Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 480
HDTV.ru > Это интересно > Уникальный 42-дюймовый ЖК-телевизор Philips 42PFL9900D/10 Aurea
Уникальный 42-дюймовый ЖК-телевизор Philips 42PFL9900D/10 Aurea29.02.2008 |
Специалисты Philips уверены, что в наши дни покорить покупателя техническими характеристиками не так просто. А ведь ЖК-телевизоры этой марки являются одними из лучших на рынке! По их мнению, нужно предлагать не просто качественное изображение, а настоящее зрелище, в прямом смысле выходящее за рамки экрана. Так когда-то появилась технология Ambilight, на первых порах являвшаяся лишь скромной локальной подсветкой стены позади экрана. Пройдя несколько ступеней эволюции, она превратилась в феерический комплекс Ambilight Spectra и стала одной из ключевых особенностей новейшего плоскопанельного ТВ класса Full HD, флагмана Philips — удивительного Aurea. Одной из ключевых, но далеко не единственной из числа заслуживающих пристального внимания. Несмотря на то, что у Philips Aurea есть свой заводской индекс (42PFL9900D/10), запоминать его нет нужды: такой телевизор в гамме голландского гиганта один. Это 42-дюймовый аппарат крайне необычного вида, «набитый под завязку» лучшими наработками Philips. Отсюда и розничная цена, составляющая 150 000 рублей. Но все логично: не имеющий аналогов среди продукции других производителей, Aurea не может стоить на уровне обычных моделей. Поставляется телевизор в красочной упаковке, в которой можно обнаружить не только пульт и необходимую документацию, но и фирменный кронштейн для настенного монтажа. Впрочем, этот Philips совместим и со стандартными креплениями форм-фактора VESA 600×400. Внешний вид В коробке телевизор находится уже в собранном состоянии — то есть, уже с прикрепленной стеклянной подставкой, имеющей опору из металла и пластика. На ней телевизор может поворачиваться в горизонтальной плоскости. Корпус Aurea по форме напоминает раму от картины: экран немного утоплен по отношению к внешнему краю обрамления. Фасад выполнен из молочно-матового полимера с серебристой каймой. Стоит отметить, что толщина обрамления матрицы непривычно большая, как и толщина корпуса в целом, из-за чего на фотографии этот Philips кажется телевизором существенно меньшей диагонали. Но на то есть свои причины: в рамке спрятан не только контур подсветки системы Ambilight Spectra, но и 24 компактных широкополосных динамика, излучающих, в том числе, через незаметную перфорацию по бокам экрана. В свою очередь две низкочастотные головки установлены позади матрицы. Совершенно очевидно, что все это оборудование компактно разместить Крайне затруднительно. Вдобавок, тот самый молочно-белый пластик рамки играет заметную роль в работе Ambilight Spectra, но об этом позже. Левый торец корпуса примечателен AV-входом, а на правом расположены элегантные вытянутые кнопки. Функции они выполняют вполне стандартные: переключение каналов/видеовходов, регулировка громкости, включение/выключение телевизора. Дополнительная клавиша «menu» открывает доступ и к интерфейсу настроек, хотя очевидно, что по нему удобнее «бродить» при помощи пульта. О самом пульте можно сказать много лестного. Он красив, элегантен, добротно сделан, но при этом легкий. Одобрение экспертов вызвала и аккуратная декоративная подсветка некоторых элементов контроллера. Пульт позволяет управлять не только собственно ТВ, но и тремя дополнительными устройствами Philips или других марок. Это может быть, например, проигрыватель DVD или «синих» дисков, спутниковый ресивер и рекордер. Коммутация Как и полагается телевизору такого класса, Philips Aurea наделен богатейшими коммутационными возможностями. На тыловой панели размещены как аналоговые (SCART и компонентный), так и цифровые входы. Последние представлены тремя портами HDMI v1.3a с поддержкой протокола CEC (Consumer Electronic Control), благодаря которому через интерфейс телевизора можно управлять совместимым проигрывателем или иным компонентом, даже если тот находится в закрытой тумбе или вообще в другой комнате. Компьютер также предполагается подключать по HDMI — при помощи переходника DVI-HDMI, если потребуется. На левом торце корпуса находится композитный видеовход и сопутствующая стереопара, вход S-Video и порт USB 2.0. К последнему можно подключать накопители данных (нпример, флэш-драйвы) для воспроизведения музыки в формате МР3, а также отображения картинок в JPEG и слайд-шоу на экране ТВ. Нетрудно догадаться, что какой-либо дополнительный плеер для этого не требуется. Вдобавок, Aurea располагает удачным экранным интерфейсом встроенного медиаплеера, поэтому вполне полноценен в этой ипостаси. Возможности Что должен уметь телевизор? В первую очередь — хорошо показывать. Как мы уже выяснили, с коммутационными возможностями у Philips Aurea все в порядке, есть даже некоторый задел на будущее (подразумевается потенциал интерфейса HDMI v1.3a). В активе модели наличествует и матрица Full HD. Все это является достойным базисом. Остается выяснить, каким потенциалом обладает электроника — один из главных компонентов, способствующих получению качественного изображения. Людям, не понаслышке знакомым с плоскопанельными телевизорами Philips, хорошо известен богатый ассортимент цифровых «примочек» для оптимизации качества видеоряда. В Aurea он достиг своего апогея, даже если не принимать во внимание стандартные регулировки яркости, контрастности, четкости, цветовой насыщенности и цветовой температуры. Начнем по прядку. Алгоритм Perfect Pixel HD Engine — всеобъемлющая система коррекции изображения с попиксельным анализом и обработкой. Оптимизации подвергаются все аспекты — от цветопередачи до детализации. Несмотря на наличие этой комплексной системы, пользователю доступны так называемые тематические алгоритмы. Их несколько. Digital Natural Motion занимается межкадровыми переходами, производя «интеллектуальную» интерполяцию потока для обеспечения максимальной плавности, «текучести» видеоряда. С его помощью художественный фильм становится похож на документальный: напрочь исчезает дискретность движений. Система 100 Hz Clear LCD обеспечивает максимально точную детализацию и дополнительную четкость движущихся объектов, предотвращая не только их смазывание, но деструктуризацию во время быстрых перемещений в кадре. Она же устраняет мерцание на экране. Бегающие животные, гоночные болиды F1, стаи птиц, вид из кабины пилота истребителя — есть уйма ситуаций, когда она может оказаться полезной. Поддерживается ли нужная скорость на уровне матрицы? Да! Время отклика пикселей составляет всего 3 миллисекунды. Также имеются система динамической контрастности (поддержание максимальной зрелищности в любых сценах без ущерба для проработки полутонов), технология автокоррекции цветовой палитры, цифровой шумоподавитель и — отдельно — нейтрализатор артефактов кодирования MPEG. Что приятно — все фирменные алгоритмы могут быть выключены или включены по желанию пользователя, причем в любой комбинации. Это открывает огромные возможности при точной настройке Philips Aurea. Для адаптации видеоряда под формат экрана предусмотрено четыре фиксированных режима и один автоматический. Среди настроек звука можно обнаружить пятиполосный эквалайзер, системы усиления баса и расширения стереобазы (на основе алгоритмов компании BBE), регулировку баланса, принудительный режим моно и динамический процессор, избавляющий от резких перепадов уровней громкости. Громкость встроенных динамиков и подключенных наушников регулируется независимо, что ценно. Характеристики
* информация о типе матрицы получена по характерным визуальным признакам, точных данных в документации не приводится. Яркая особенность Известно, что технология Ambilight призвана визуально расширить площадь экрана за счет подсветки стены позади ТВ — так было с самого начала, когда она только появилась в ЖК-телевизорах Philips около восьми лет назад. В последних версиях эта подсветка стала динамической и полноцветной, газоразрядные лампы уступили место светодиодам, которые и работают быстрее, и ресурс имеют существенно больший, сравнимый с ресурсом самого телевизора. Но Ambilight Spectra — это принципиально новый уровень визуализации. В корпусе Philips Aurea установлено в общей сложности 126 мощных светодиодов, способных отобразить практически любой цвет, причем с плавным переходом от одного оттенка к другому. И подсвечивается в данном случае не только пространство за телевизором, но и рамка экрана. Целиком! Зрелище поистине фантастическое! Специальный процессор анализирует видеоряд и перенастраивает подсветку в реальном времени — синхронно с изображением. Причем, если «картинка» состоит из нескольких разноцветных областей, то и подсветка делится на цветовые зоны в нужных пропорциях. Для наглядности мы сделали несколько фотографий, на которых отлично видна работа Ambilight Spectra. Разумеется, для достижения максимального эффекта надо выполнить несколько условий. А именно: позади телевизора, в 10—20 сантиметрах, должна располагаться светлая — желательно белая — поверхность, а собственно просмотр имеет смысл проводить в полумраке, а лучше — в полной темноте. Подсветка в Philips Aurea — конфигурируемая. Присутствует возможность изменять яркость и режим синхронизации с видеосигналом, интенсивность цветовой палитры и алгоритм деления цветовых зон. С таким арсеналом Ambilight Spectra может как ненавязчиво помогать восприятию, так и создавать эффектное световое шоу. Обилие настроек и возможность полного отключения не делают эту систему навязчивой — включайте, когда душа попросит. Благо, делается это нажатием одной кнопки на пульте. По мнению автора этих строк, передачи про природу, красивые видовые фильмы и спортивные состязания с работающей на полную катушку Ambilight Spectra выглядят просто великолепно. Еще одно, на первый взгляд неожиданное, но вполне логичное применение этой технологии и Philips Aurea в связи с ней — дизайн интерьеров. В частном доме ли, в модном клубе ли, в казино — кому на что хватит фантазии. В этом случае телевизор будет выполнять не только прямые обязанности. Он станет одним из задающих настроение элементов. Тестируем Для тестирования видеотракта мы использовали наш редакционный BD-проигрыватель Samsung BD-P1000 с комплектом тестовых дисков Blu-ray и DVD, а также универсальный HD-плеер Dune HD Ultra, который использовали для воспроизведения отдельных видеороликов (видеофайлов) высокого разрешения. Подключение обоих устройств производилось по HDMI. Если честно, то долго расписывать впечатления от тестирования не станем. Дело в том, что Aurea обеспечивает, пожалуй, максимальный уровень качества, который вообще возможен для современного жидкокристаллического телевизора. Судя по легкому сиреневому оттенку при взгляде на экран под углом, в Philips Aurea используется матрица S-IPS нового поколения — о начале их производства сообщалось некоторое время назад. Предельно корректные цвета и прекрасная проработка полутонов — вот основные достоинства этой матрицы. А будучи обильно «сдобренной» электронными алгоритмами обработки видеосигнала, она и вовсе способна творить чудеса. Неудивительно, что все записи в High Definition были отсмотрены экспертами «от корки до корки»: изображение оказалось замечательным — комфортным, глубоким, почти живым. Не возникло никаких проблем с проработкой темных и самых ярких областей. В то же время, от «услуг» некоторых цифровых обработок мы намеренно отказались, так как они пытались улучшить и без того изначального качественный видеоряд. Получалось своеобразно — на любителя… При просмотре DVD-Video те же обработки были более актуальны, но и тут, как оказалось, не трудно переступить черту между предельно качественным и стерильно-синтетическим изображением. Это не значит, что цифровые алгоритмы Philips малоэффективны. Просто электроника телевизора настолько мощная, что в большинстве случаев хватает даже минимальных значений интенсивности вмешательства. При этом некоторые «улучшайзеры» имеет смысл выключить вовсе. Возможно, весь потенциал цифровой «начинки» окажется востребован лишь при отображении сигнала с низкокачественных источников — таких, как телеэфир или видеомагнитофон VHS. Хотя, учитывая класс и цену этого ТВ, в подобные сценарии верится с трудом. Поэтому предостережем потенциальных покупателей Philips Aurea: не спешите включать все фирменные видеообработки на максимум. Только грамотное манипулирование столь богатым инструментарием поможет достичь отличного результата. Встроенная аудиосистема, состоящая из множества динамиков, обеспечивает неплохую проработку высоких и низких частот. Тем не менее, откровением звучание не стало — да и могло ли? Акустика ТВ призвана озвучивать новости да сериалы, полноценного домашнего кинотеатра она не заменит ни при каких обстоятельствах. Со своими задачами динамики Philips справляются достойно, при том что вообще не видны. А значит — и в этой дисциплине зачет. Выводы Philips Aurea уникален и практически лишен недостатков: он красив, отлично сделан, очень хорошо показывает, богато оснащен. Цена? Да, очень большая, учитывая диагональ экрана. Но и удивительная подсветка Ambilight Spectra есть только у этого телевизора. Нужна ли она — пусть каждый решает для себя сам. Достоинства:
Недостатки:
Вернуться назад |
