Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 «Выходные с Dune HD» #23
HDTV.ru > Это интересно > «Выходные с Dune HD» #23
24.04.2015
Онлайн-кинотеатр ivi.ru опубликовал сиквел популярной отечественной драмы «Духless». Он вышел на большие экраны в начале марта 2015-го года и уже доступен для легального онлайн просмотра в Интернете. Стоимость доступа к картине – всего двести рублей. «Виртуальный билет» действителен в течение месяца с момента оплаты и в течение сорока восьми часов с начала просмотра. Лента не рекомендована для просмотра лицам младше шестнадцати лет. Бюджет картины - 140 000 000 рублей, сборы в России превысили отметку в семь с половиной миллионов рублей. К сожалению, сиквел не смог повторить триумф оригинальной картины, которая собрала в прокате более тринадцати миллионов рублей. Тем не менее, зрители оценили вторую часть также, как и первую: рейтинг на «Кинопоиске», соответственно, 6,5 балла из десяти и 6,6 балла.
«Духless 2» – официальный постер
Молодой, дерзкий, успешный, холеный – главный героев первого фильма «Духless» Макс Андреев потерял все, что имел: дорогую квартиру, статусную машину, престижную работу. Но главное, он потерял смысл жизни. Обрести себя заново, проповедуя осознанный дауншифтинг, герой пытается в продолжении самого кассового российского фильма 2012 года. Первую часть картины принято считать «современной версией Евгения Онегина». Над сценарием сиквела вновь потрудился Сергей Минаев – автор одноименного романа, в свое время вызвавшего небывалый интерес читающей публики. Детали сюжета держались в строжайшем секрете на протяжении всего съемочного процесса: создатели уверенно заявляли лишь одно – эта драма тоже создана цеплять актуальностью описываемых событий, реалий и настроений. Главный герой отказался от всего, что так когда-то ценил — светской жизни, успешной карьеры, роскошного пентхауса. Теперь его стихия — океан. Каждый день он рассекает на серфе теплые волны, омывающие остров Бали. Но невозможно забыть ритм большого города. Случайное знакомство возвращает его в самое сердце современной столицы — высокие технологии, сумасшедшие сделки, смертельный риск и прежняя любовь, которая больше не с ним…
«Духless 2» – официальный трейлер
Примечательно, что для того, чтобы лучше соответствовать своей роли, Данила Козловский брал уроки серфинга – большинство трюков в фильме он исполнил самостоятельно. Съемки проходили на острове Бали и в Москве. Также в фильме снялись Мария Андреева, Милош Бикович, Павел Ворожцов, Александра Бортич, Кристина Бабушкина и другие. Режиссер картины – Роман Прыгунов.
«Призрак» – официальный постер
Помимо «Духless 2», онлайн-кинотеатр ivi.ru опубликовал еще одну свежую отечественную ленту. Речь идет о картине «Призрак» режиссера Александра Войтинского, которая вышла в прокат на последней неделе марта. Уже сейчас, спустя месяц, после выхода на большие экраны, фильм можно посмотреть легально онлайн. Стоимость доступа к картине – 300 рублей на два дня с момента начала трансляции. Главные роли в фильме исполнили Фёдор Бондарчук и Семен Трескунов, на вторых планах – Ян Цапник, Анна Антонова, Игорь Угольников, Ксения Лаврова-Глинка, Софья Райзман и другие. Фильм можно смотреть с детьми: возрастной рейтинг – 6+. В России фильм посмотрели более полутора миллионов зрителей, принеся в кассу картины $3,25 миллиона. Примечательно, что ленту до сих пор показывают во многих кинотеатрах.
«Призрак» – официальный трейлер
Сюжет у картины следующий. Юрий Гордеев — талантливый авиаконструктор, создатель инновационного самолёта ЮГ-1. Он планирует показать возможности самолёта на грядущем авиасалоне в Жуковском и выиграть правительственный тендер. Но за несколько дней до салона Юрий садится в пьяном виде за руль и разбивается в автокатастрофе. Он становится призраком, которого никто не видит, кроме школьника Вани Кузнецова, случайно встреченного на улице. Ваня — закомплексованный подросток, страдающий от опеки матери, неразделённой любви и издёвок одноклассников. Однако Гордеев понимает, что мальчик — единственный шанс довести дело до конца и поднять новый самолёт в небо. В итоге они объединяют усилия, чтобы решить проблемы друг друга. Им приходится противостоять Ползунову, конкуренту Гордеева, который хочет во что бы то ни стало заполучить тендер себе.
«Призрак» – кадр из фильма
Самолет будущего ЮГ-1, конструктором которого является Юрий Гордеев — герой Фёдора Бондарчука, сделан полностью с помощью компьютерной графики компании MainRoad Post. Так как никакие самые современные аналоги и высокотехничные декорации не смогли передать всей уникальности этого самолета. Примечательно, что «Призрак» стал первым российским фильмом, при создании которого применялась звуковая технология Dolby Atmos. Во время съемок фильма актер Ян Цапник в действительности сломал ногу, из-за чего был переписан сценарий одной из финальных сцен с его участием. И, на десерт, небольшой сценарный ляп: персонаж Фёдора Бондарчука после смерти отбрасывает тень на асфальт, что невозможно, так как он дух, а духи «невидимы».
«Женщины против мужчин» – официальный постер
Самой свежей лентой нашего сегодняшнего дайджеста стала картина «Женщины против мужчин». Она вышла на большие экраны, без малого, всего две недели назад – девятого апреля. Уже сейчас портал Megogo.net получил эксклюзивные права на трансляцию картины. Стоимость виртуального билета для просмотра онлайн «Женщины против мужчин» – всего сто рублей на неделю или двести рублей навсегда. Билет в кино, даже на одного человека, оказался бы значительно дороже. Фильм «Женщины против мужчин» — весенняя премьера 2015 года. Российская комедия вышла из-под пера Таира Мамедова – бывшего резидент Comedy Club, Сергея Нежданова и Леонида Марголина. Свадебно-романтическая лента превращается в войну женщин с мужчинами с первых же минут. Причина битвы — юношеский максимализм, разогретый жарким кубинским солнцем и подлитые, как масло в огонь, явно несвоевременные комментарии подруг и друзей.
«Женщины против мужчин» – официальный трейлер
Школьная любовь трех замечательных пар заканчивается тремя прекрасными свадьбами и сумасшедшим свадебным путешествием на экзотическую и горячую Кубу. Но первый же день долгожданного медового месяца окончился гигантской ссорой, переходящей в вечную войну мужчин против женщин. А на войне, как и в любви, правил нет! Пираньи в бассейн? Запросто! Пожар в номере? Не вопрос! Флирт на глазах у любимого мужа? Однозначно, да! И все это, конечно же, во имя любви!
Меню козней и ассортимент коварства заставляет позавидовать натренированному воображению сценаристов. Нескончаемый перечень упрёков, сыплющихся с экрана, как со стороны сильной, так и прекрасной половин человечества, говорит о глубоком знании авторами данного вопроса. Непонимание особенностей друг друга возведено в высшую степень, выпячено настолько явно, что становится гротеском. Возможно, кому-то из зрителей данное преувеличение поможет решить даже какие-то личные вопросы, наконец-то ощутив бревно в глазу. Такая позитивная педагогически-психологическая нагрузка ленты отнюдь не исключена. После серой зимы смотреть фильм «Женщины против мужчин» — одно удовольствие, глаз радуется. Лазурный океан, белоснежный песок, яркое солнце — картинка в преддверии лета вне всяких похвал. Почему бы и не провести 80 минут с попкорном в руке, следя за разворачивающимися событиями на экране, внимая тинейджерским шуткам, оценивая постоянные стычки главных героев.
«Женщины против мужчин» – кадр из фильма
Главные роли в картине исполнили звезды Comedy Club Production: Роман Юнусов, Александр Головин, Денис Косяков, Мария Кравченко, Настасья Самбурская и Наталья Рудова, а также Таир Мамедов и Олег Верещагин. Стоимость картины – 50 миллионов рублей. За две недели проката ее посмотрели более шестисот тысяч зрителей. Фильм не предназначен для детей младше восемнадцати лет.
«Неуловимые» – официальный постер
На закуску мы оставили криминальную комедию «Неуловыимые» режиссера Артема Аксененко. Этот фильм ориентирован на молодежную аудиторию, картину можно смотреть детям с двенадцати лет. Слоган ленты: «Молодые изменят мир». Главные роли в фильме исполнили Александра Бортич, Иван Шахназаров и Илья Маланин, также в картине снялись Анвар Халилулаев, Денис Шведов, Евгений Мундум, Джемал Тетруашвили, Ксения Баскакова и другие. Стоимость ленты – полтора миллиона долларов. Правда, в прокате в России она не отбила и трети бюджета. Картину посмотрели всего 150 тысяч зрителей. Лента вышла в прокат 26 марта 2015 года, а в конце апреля она выйдет на Blu-ray и DVD.
«Неуловимые» – официальный трейлер
Сюжет у фильма следующий. Ночью в центре Москвы сбита девушка, ей срочно нужна сложнейшая операция. Ее подруга Кира находит виновника, наглого и циничного олигарха Сергея Полянского, который отказывается признать свою вину и помочь пострадавшей. Ему плевать, у него все схвачено. В отчаянии Кира обращается за помощью к трем парням симпатизирующим ей — быковатому Феде, самоуверенному красавчику Артему и компьютерному гению Жене. Парни заключают между собой пакт — «поможем девушке, накажем негодяя, а потом решим, кто станет ее парнем».
Фильм «Неуловимые» опубликован для легального онлайн-просмотра на портале Megogo. Стоимость доступа к картине на неделю – 99 рублей, навсегда – 199 рублей. Примечательно, что смотреть кино можно не только на ПК, но и на различных гаджетах, Smart TV и мультимедийных приставках Dune HD.
Вернуться назад
