Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Обзор телевизоров Panasonic 2015
HDTV.ru > Это интересно > Обзор телевизоров Panasonic 2015
12.04.2015
Компания Panasonic одной из первых, еще в феврале представила европейский модельный ряд своих телевизоров Viera образца 2015 года. Большинство новых телевизоров имеют разрешение Ultra HD, а ряд моделей поддерживают также еще расширенный яркостной диапазон (HDR) и расширенную цветовую палитру. Японская компания переходит на Firefox OS в качестве новой телевизионной платформы, которая будет интегрирована в модели среднего и высшего класса. Panasonic выпустит также свои первые телевизоры с изогнутым экраном. Давайте рассмотрим новый модельный ряд телевизоров японской компании.
Следите за последними новостями в мире телевизоров и видеотехники на страницах нашего сайта.
Телевизоры Panasonic 2015
Panasonic имеет полную линейку телевизоров сверх высокого разрешения, от моделей начального уровня до самых высокотехнологичных UHDTV. Компания предлагает и несколько серий HDTV, но ясно, что приоритетом для Panasonic в этом году является Ultra HD. Вместо простого повышения разрешения телеэкрана компания переходит к концепции «усовершенствованных пикселей».
Уже на январской выставке CES 2015 были представлены первые образцы новых моделей телевизоров с поддержкой HDR, расширенной цветовой палитры на основе ЖК панелей с 10-битным цветом. В течение года компания начнет массовый выпуск и продажи нового поколения телевизоров. Вы можете ожидать великолепное по качеству изображение с более яркими светлыми и более глубокими темными оттенками, более впечатляющими цветами. Panasonic заявляет, что телевизоры были разработаны в сотрудничестве с голливудской студией, но все-таки компания не делает никаких анонсов относительно доступного в этом году контента.
Для поддержки HDR и расширенной цветовой палитры Panasonis разработал новый процессор 4К Studio Master, используемый в моделях наиболее высокого класса, которые также будут оснащены LED подсветкой с локальным затемнением для повышения контрастности, используют фосфорную LED технологию для расширения цветовой гаммы. Модели телевизоров среднего класса все же не дотягивают по формальному рейтинговому показателю до уровня «усовершенствованных пикселей», но, в действительности, вы все-же получите более достоверную картинку в разрешении 4К.
Во внешнем облике телевизоров из последнего семейства японской компании продолжает доминировать минималисткий стиль, принятый в последние годы всеми производителями. Очень узкое обрамление экрана, сверх плоский и элегантный корпус - составляющие этого дизайна. Panasonic в этом году предлагает широкий выбор по типу настольных подставок, включая те, что с опорой по центрe экрана и смещенной по бокам.
В 2015 году Panasonic выпустит свои первые модели телевизоров с вогнутой плоскостью экрана. Будут доступны три подобных серии телевизоров (CR850, CR730, CR430), включая модели очень высокого класса. Изогнутые телевизоры анонсированы были только для Европы. Европейцы также могут рассчитывать на двухканальные тюнеры и домашнее сетевое ТВ, что позволяет смотреть телевизионные каналы с встроенного тюнера телевизора на экране планшета или смартфона. Телевизор позволит передавать видеозаписи на другие дисплеи (TV Anywhere), где бы вы ни находились в доме.
Еще одна знаковая новинка в модельном ряде телевизоров Panasonic 2015 – это новая встраиваемая операционная система Firefox OS. Panasonic отказывается от прежней платформы Smart Viera и переходит на Firefox OS с интуитивно понятным и удобным пользовательским интерфейсом, с телегидом Xumo и единой строкой поиска. Пока еще не представлен полный перечень поддерживаемых приложений, следите за нашими новостями.
Некоторые из основных конкурентов компании Panasonic в телевизионной индустрии решили перейти в этом году на Android TV от Google, но Panasonic считает, что собственная операционная системы на основе открытых веб-стандартов позволит предлагать больше приложений и лучшего качества. Это интересный выбор, и только время покажет, сможет ли Panasonic прописать Firefox в вашей гостиной. Телевизоры, выпущенные в 2014 году и ранее не могут быть обновлены до уровня Firefox OS.
Говоря о "Smart TV", необходимо отметить, что все телевизоры Panasonic на базе Firefox будут оборудованы декодерами HEVC, которые необходимы для приема цифровых 4K сигналов из сети и эфира. Panasonic уже заявил о сотрудничестве с сетевыми сервисами, предлагающими видео в разрешении 4K.
Первые Ultra HD Blu-ray плееры Panasonic должны быть готовы уже в этом году, но никаких конкретных деталей компания пока еще представила. Прототип плеера уже демонстрировался в начале года и следует отметить, что для того, чтобы в полной мере воспользоваться всеми достоинствами таких источников видео в новом формате, вам понадобится один из высококачественных телевизоров 2015 года. Американский видео сервис Netflix уже заявил о поддержке 4K видео с HDR в течение этого года и Panasonic утверждает, что видео с Netflix будет доступно на экранах Panasonic.
Panasonic также подчеркивает использование «умных" функций, включая интегрированный "Голосовой помощник", который позволяет управлять телевизором. Обеспечена поддержка DLNA, воспроизведение медиа файлов через порт USB, есть функция "Swipe и Share", что позволяет передавать видео, фото и другие видео материалы с вашего смартфона или планшета на телевизор через браузер Firefox (или совместимые приложения) Это, конечно, пока не Google Cast, но Mozilla работает над совершенствованием и расширением системы Firefox.
C Firefox OS Panasonic планирует выйти на рынок устройств для , «Умного дома». Новые телевизоры на основе Firefox должны стать центральным пунктом управления вашего дома с возможностью управления всеми интеллектульными устройствами. Это долгосрочная стратегия, но Panasonic заявляет, что некоторые из функций, такие как уведомления, будут доступны уже в 2015 году.
Первые телевизоры из модельного ряда Panasonic 2015 года будут доступны уже весной. Модели высокого класса появятся в продаже позже. Мы будем следить за анонсами компании, заходите на страницы сайта hdtv.ru.
Panasonic CX850
PANASONIC CX850 (4K)
Panasonic CX850 - флагманская серия телевизоров японской компании для североамериканского рынка. Модели этой серии не будут продаваться в Европе. Panasonic CX850 – это наиболее совершенные телевизоры японской компании на основе Firefox OS
• 4K Ultra HD
• 4K Studio Master Processor
• 98 % охват цвета DCI
• Local Dimming Pro
• Поддержка HDR (супер яркая панель)
• 10-битный цвет
• HEVC
• HDMI 2.0
• Firefox OS
• 4-х ядерный процессор
• Сертификация THX 4K (в процессе)
США: 55" TC-55CX850U и 65" TC-65CX850U
Европа: Не поставляется.
Panasonic CR850
PANASONIC CR850 (4K)
Телевизоры серии Panasonic CR850 являются одними из самых высокотехнологичных моделей нынешнего года. В них применены изогнутый дизайн и все передовые технологии Panasonic для повышения качества 4К изображения, включая поддержку HDR и расширенной цветовой гаммы. Здесь также используется Firefox OS.
• Изогнутый экран
• 4K Ultra HD
• 1600 BMR
• Процессор 4K Studio Master
• Local Dimming Pro
• 10-битный цвет
• HEVC
• HDMI 2.0
• Домашнее потоковое ТВ
• TV Anywhere
• Двухканальный тюнер (только в Европе)
• Firefox OS
США: не поставляется
Европа: 55" TX-55CR850 и 65" TX-65CR850
Panasonic CX800
PANASONIC CX800 (4K)
Модели серии CX800 подобны CR850, но с плоским экраном. Они оснащены теми же самыми видео технологиями и Firefox OS.
• 4K Ultra HD
• 1600 BMR
• Local Dimming Pro (нет в 40-дюймовой модели)
• 10-битный цвет
• HEVC
• HDMI 2.0
• TV Anywhere
• Firefox OS
США: 55" TC-55CX800U, 60" TC-60CX800U и 65" TC-65CX800U
Европа: 40" TX-40CX800, 50" TX-50CX800, 55" TX-55CX800 и 65" TX-65CX800
Panasonic CX750
PANASONIC CX750 (4K)
Ступенью ниже от восьмого семейства наиболее высококлассных телевизоров Panasonic расположилась серия CX750. Здесь уже нет поддержки таких технологий нового поколения, как HDR и расширенная до требований DCI цветовая гамма. Вместо них использованы более «базовые» для Ultra HD технологии, включая Firefox OS и HEVC.
• 4K Ultra HD
• 1000 BMR
• HEVC
• HDMI 2.0
• Супер яркая панель IPS
• TV Anywhere
• Firefox OS
Европа: 43" TX-43CX750, 49" TX-49CX750, 55" TX-55CX750 и 60" TX-60CX750
Panasonic CR730
PANASONIC CR730 (4K)
CR730 - это изогнутая версия серии X750, лишь с небольшими отличиями. Здесь уже нет двухканального тюнера, но присутствует Firefox OS и декодирование HEVC.
• Изогнутый экран
• 4K Ultra HD
• 1000 BMR
• Studio Master Drive
• Локальное затемнение
• HEVC
• HDMI 2.0
• TV Anywhere
• Firefox OS
Европа: 55" TX-55CR730 и 60" TX-60CR730
Panasonic CX700
PANASONIC CX700 (4K)
CX700 – еще одна серия Ultra HD телевизоров Panasonic, все еще с Firefox OS, приложениями и домашним ТВ, когда телевизор позволяет передавать телевизионные каналы на дисплеи планшета или смартфона
• 4K Ultra HD
• 800 BMR
• HEVC
• HDMI 2.0
• TV Anywhere
• Firefox OS
Европа: 40" TX-40CX700, 50" TX-50CX700, 55" TX-55CX700 и 65" TX-65CX700
Panasonic CX680
PANASONIC CX680 (4K)
Телевизоры этой серии являются наиболее доступными в Европе Ultra HD телевизорами Panasonic с Firefox OS. Они включают наиболее важные для сегодняшних 4K телевизоров технологии, в том числе HEVC и HDMI 2.0.
• 4K Ultra HD
• 200 BMR
• HEVC
• HDMI 2.0
• TV Anywhere
• Firefox OS
США: Не поставляется.
Европа: 40" TX-40CX680, 50" TX-50CX680 и 55" TX-55CX680
Panasonic CX650
PANASONIC CX650 (4K)
В сериях CX650 и CX600 Panasonic предлагает модели для рынка США. Основная разница между ними в поддержке Firefox OS.
• 4K Ultra HD
• 240 Гц (CX650) / 120 Гц (CX600)
• 90 % охват цвета DCI
• HEVC
• HDMI 2.0
• Firefox OS
США: 55" TC-55CX650U, 60" TC-60CX650U и 65" TC-65CX650U. В CX600 только 50" TC-50CX600U без поддержки Firefox OS (в остальном те же характеристики).
Panasonic CX400
PANASONIC CX400 (4K)
В этой серии будут выпускаться Ultra HD TV начального уровня, без Firefox OS. Они имеет только медиа-плеер и ограниченный набор приложений. Помните, что вам понадобится дополнительная приставка для приема 4K видео из сети.
• 4K Ultra HD
• 400 RMR (только 55» и 65")
• HDMI 2.0
• USB медиа плеер
Европа: 40" TX-40CX400, 48" TX-48CX400, 55" TX-55CX400 и 65" TX-65CX400
Panasonic CR430
PANASONIC CR430 (4K)
Эта серия во многом аналогична CX400, но с изогнутыми экранами. Это простой телевизор сверхвысокого разрешения без интеллектуальных функций на базе Firefox OS и возможности приема 4К видео из сети. В случае появления такой возможности, покупателю придется купить внешнюю приставку с поддержкой приема 4К видео из сети. В серии CR430 будет выпускаться только 55-дюймовая модель.
• Изогнутый экран
• 4K Ultra HD
• 400 RMR
• HDMI 2.0
• USB медиа плеер
Европа: 55" TX-55CR430
Panasonic CS600
PANASONIC CS600
Panasonic будет в этом году выпускать несколько моделей телевизоров с Full HD разрешением. Наиболее совершенные из них сосредоточены в серии CS600, Но это все-таки в большей степени базовые модели без поддержки Firefox OS.
• Full HD
• 100 (32") / 200 (40" и 50") / 400 BMR (55» и 65")
• TV Anywhere
• USB медиа плеер
Европа: 32" TX-32CS600, 40" TX-40CS600, 50" TX-50CS600, 55" TX-55CS600 и 65" TX-65CS600
Panasonic CS500
PANASONIC CS500
В этой серии выпускаются модели HDTV с достаточно базовыми возможностями.
• Full HD
• 100 (24" и 32") / 200 (40" и 50")
• USB медиа плеер
Европа: 24" TX-24CS500, 32" TX-32CS500, 40" TX-40CS500 и 50" TX-50CS500
Вернуться назад
