Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 «Выходные с Dune HD» №15
HDTV.ru > Это интересно > «Выходные с Dune HD» №15
27.02.2015
Онлайн-кинотеатр AMEDIATEKA полностью опубликовал для авторизованного просмотра американский многосерийный фильм «Джон Адамс». Лента состоит из семи эпизодов, каждый продолжительностью чуть более часа. Сериал произведен телеканалом HBO. Режиссер и автор идеи – Том Хупер, сценарий основан на одноимённой книге Дэвида Маккалло, которая рассказывает о втором президенте США – том самом Джоне Адамсе. Главную роль в картине исполнил Пол Джиаматти, роли второго плана сыграли Лора Линни, Стивен Диллэйн, Дэвид Морс, Том Уилкинсон, Дэнни Хьюстон, Руфус Сьюэлл, Джастин Теру и Желько Иванек. Сериал получил четыре «Золотых глобуса» в 2009-м году: за лучших актера и актрису, за лучшего актера второго плана и за лучший мини-сериал или фильм на телевидении. Также «Джон Адамс» получил тринадцать премий «Эмми».
Сериал рассказывает о том, с чего начиналась карьера Джона Адамса. Главный герой с семьей живёт в Бостоне и зарабатывает на жизнь частной юридической практикой. В одну из ночей 1770 года он становится свидетелем кровавого столкновения между британскими военнослужащими и местными жителями, недовольными налоговой политикой метрополии. В результате конфликта имеются убитые и раненые. Джон Адамс, рискуя своей репутацией, берётся защищать британских солдат в суде. В начале процесса обвинение настаивает на том, что капитан Томас Престон осознанно отдал приказ открыть огонь по безоружным людям. Присутствующие в зале горожане эмоционально требуют сурового наказания для английских солдат. Успех Адамса в этом громком деле резко повышает его авторитет и популярность. От имени Георга III ему предлагают выгодную должность в колониальной администрации. С другой стороны, лидеры патриотически настроенных сил, «сыны свободы», дают понять Адамсу, что тоже рассчитывают на его поддержку и участие. Джон не видит себя в политике, поэтому отказывается. Он заявляет, что намерен посвятить свою жизнь научной деятельности и служению Закону. Однако растущее напряжение в политической жизни родного Массачусетса всё-таки заставляет Адамса сделать непростой выбор: он соглашается стать одним из представителей колонии в Конгрессе…
Этот сериал получил в основном положительные отзывы, как критиков, так и зрителей. Средний рейтинг картины на «Кинопоиске» – 7,85 балла из десяти возможных; пользователи ресурса IMDb оценили ее еще выше – на 8,7 балла из десяти. Примечательно, что в саундтреке к сериалу используются музыкальные произведения, бывшие лейтмотивами кинофильма Стэнли Кубрика «Барри Линдон» — это «Сарабанда» Генделя и фрагмент Фортепианного «Трио № 2» Шуберта. Доступ к сериалу «Джон Адамс» на портале AMEDIATEKA доступен по подписке.
Онлайн-кинотеатр Vidimax полностью опубликовал отечественный сериал «Грач». Режиссеры и авторы идеи – Андрей Волгин, Максим Кондратенко, в ролях - Павел Трубинер, Светлана Иванова, Игорь Старосельцев, Алексей Лонгин, Александр Баширов, а также звезды сериала «Интерны» Иван Охлобыстин и Вадим Демчог. Шоу транслировалось по первому каналу в 2012-м/2013-м годах. Доступ к сериалу предоставляется только авторизованным пользователям, оформившим платную подписку.
Главный герой телесериала — майор МВД Сергей Грачев, по прозвищу «Грач». Во время операции по освобождению заложника майор получает пулю в голову. Он чудом избегает смерти, несмотря на то, что врачи не смогли извлечь пулю. Ранение полностью меняет жизнь Грача. Он пережил клиническую смерть, видел таинственный «тоннель», о котором рассказывают многие умирающие. И, самое главное, Грачу начали являться призраки — духи убитых людей, чьи убийцы до сих пор не найдены.
Отвечая на молчаливые просьбы умерших, используя их подсказки, Грач поднимает и расследует старые, безнадежные дела. Большинство знакомых и коллег считают майора сумасшедшим. Жена Грача оставляет попытки поправить не слишком удачную семейную жизнь и уходит. Одновременно с расследованиями старых, давно забытых и «сложенных на полку» убийств Грач пытается понять природу своего странного дара, который помогает ему в раскрытии преступлений, а также наладить свою непростую личную жизнь. Шанс Грача на счастье — его подчиненная, капитан Даша Охлопкова, одна из немногих, кто верит в его дар.
На портале Megogo опубликовали одну из самых захватывающих драм 2014-го года – ленту «Одержимость» (оригинал – Whiplash) режиссера Дэмьена Шазелла. Данная картина – его дебют в полном метре. Главные роли исполнили Майлз Теллер и Дж. К. Симмонс, удостоенные за свои актёрские работы множества наград. Подавляющим большинством представителей кинопрессы «Одержимость» признана одним из десяти лучших фильмов 2014-го года. Фильм попал в ТОП-250 лучших фильмов всех времен на «Кинопоиске». На момент публикации данного материала он занимает сверхпочетную 51-ую строчку. Рейтинг фильма очень высокий – 8,5 баллов из 10. Помимо положительных отзывов от кинокритиков и зрителей, фильм получил три премии «BAFTA», один «Золотой глобус» и пять номинаций на премию «Оскар», в категориях «Лучший фильм», «Лучшая мужская роль второго плана», «Лучший звук», «Лучший монтаж» и «Лучший адаптированный сценарий». В итоге лента получила три «Оскара» – за звук, монтаж, и лучшую роль второго плана. На сайте Rotten Tomatoes фильм имеет рейтинг 95 % на основе 213 рецензий со средним баллом 8,6 из 10. Фильм не рекомендуется смотреть детям (рейтинг MPAA – R).
Эндрю Ниман, первокурсник американской консерватории, попадает под влияние деспотичного маэстро-дирижёра Теренса Флетчера. Эндрю уже превосходный барабанщик, но дирижеру этого мало, поскольку он полагает, что самая страшная похвала в мире — «Хорошо, молодец»; она вынуждает человека останавливаться и не реализовывать свой потенциал до конца. Флетчер хочет превратить Эндрю в ошеломительного джазового музыканта, сопоставимого по масштабу с Чарли Паркером, Бадди Ричем или Луи Армстронгом. И он уверен, что для этого его ученику необходимо пройти через жестокие испытания и унижения.
На одном из концертов Эндрю садится играть после автокатастрофы, из-за чего окровавленные руки его не слушаются, он портит выступление всей группы, и Флетчер выгоняет его из оркестра. Эндрю не выдерживает и нападает на Флетчера с криками и руганью прямо на сцене, после чего его отчисляют из консерватории. Эндрю бросает игру, работает в забегаловке, но однажды вновь встретив Флетчера в одном из джазовых клубов, он узнает, что тот больше не преподает в консерватории. Флетчер объясняет Эндрю, что его стиль общения с музыкантами преследует главную цель — через психологические стрессы раскрыть их талант, дать шанс достичь настоящего величия. Флетчер приглашает Эндрю без репетиций сыграть с его новым оркестром на выступлении в Карнеги-холле…
Примечательно, что название картины – Whiplash – дано в честь инструментальной пьесы джазового композитора Хэнка Леви. Премьерой фильма открылась конкурсная программа кинофестиваля «Сандэнс» 16 января 2014 года, на котором картина была удостоена главного приза. Вскоре после премьеры Sony Pictures приобрела права на международный прокат ленты. Фильм отчасти основан на личном опыте Дамьена Шазеля. Когда он учился в старшей школе, то играл в оркестре и, по словам самого Шазеля, боялся своего преподавателя. Несмотря на свой опыт игры на барабанах, Майлз Теллер брал дополнительные уроки. Три дня в неделю по четыре часа он занимался, чтобы подготовиться к съемкам фильма.
Еще несколько интересных фактов о фильме. Майлз Теллер, который играет на барабанах с 15 лет, в процессе съемок стер себе руки до волдырей. В результате палочки, которыми он играл, и сама барабанная установка были испачканы его кровью. В эти моменты режиссер специально не останавливал съемочный процесс, чтобы придать картине реализма. В итоге Теллер стучал по барабанам до изнеможения. Режиссер и сценарист фильма Дамьен Шазель никак не мог получить финансирование для фильма, поэтому он сделал из него короткометражку, которую представил на кинофестивале «Сандэнс» в 2013 году. Вскоре после успешного выступления на фестивале Шазель нашел необходимые средства. Наконец, главную роль в фильме мог получить Дэйн ДеХаан, но он отказался от нее. Съемочный процесс продлился две с половиной недели.
«Одержимость — это, в первую очередь, вербальное и эмоциональное противостояние двух музыкантов разного возраста. И здорово его продемонстрировал актёрский дуэт, состоящий из молодого Майлза Теллера, известного по комедии «Проект Х: Дорвались», и старичка Джонатана Кимбла Симмонса, сыгравших Эндрю и Флетчера соответственно. Вне зависимости от того, происходит ли на экране яростный спор или спокойный дружеский диалог, наблюдение за главными героями крайне интересное и интригующе. Одержимость — это двойственная яркая демонстрация того, на что способен целеустремленный и сильный человек. При неоднозначности персонажей, итог всё равно один: такое кино способно приятно удивить и неслабо вдохновить любого зрителя», - гласят выдержки из пресс-релиза на Megogo. Стоимость просмотра фильма на портале – триста рублей. Доступ предоставляется на неделю.
Онлайн-кинотеатр ivi.ru опубликовал еще одну знаковую для 2014-го года ленту. Речь идет о картине «Бердмен». Это «черная» комедия режиссёра Алехандро Гонсалеса Иньярриту с Майклом Китоном в главной роли. 27 августа 2014 года была представлена в основной конкурсной программе 71-го Венецианского кинофестиваля. Выход в прокат США состоялся 17 октября 2014 года – лента свежая, на дисках для домашнего просмотра в России она еще не вышла. Подавляющим большинством представителей кинопрессы признана одной из десяти лучших картин 2014 года, удостоена множества наград, включая четыре премии «Оскар» за лучший фильм, лучшую режиссерскую работу, лучшую работу оператора и лучший сценарий. Также фильм получил два «Золотых глобуса», отмечен Британской киноакадемией и Гильдией актеров.
Вписанная в основную конкурсную программу Венецианского кинофестиваля 2014 года черная комедия яркого представителя нового мексиканского кинематографа Алехандро Гонсалеса Иньярриту (режиссера таких картин как «Бьютифул» и «Вавилон») рассказывает историю актера, который рассчитывает вернуть себе былую славу. Символично, что образ стареющего Риггана Томпсона, единственной звездной ролью которого был супергерой Бёрдмен, воплотил Майкл Китон, тот самый, чьим главным достижением считается Бэтмен в фильмах Тима Бёртона.
Герой возлагает очень большие надежды на предстоящую бродвейскую постановку, но в закулисье его поджидает трудный соперник – эгоистичный интриган, за действия которого отвечает Эдвард Нортон, который, как мы помним по «Бойцовскому клубу», умеет пускать в ход кулаки. Основной конфликт оттеняется настоящими звездами Голлувуда: здесь и Эмма Стоун, и Наоми Уотс, и большой затейник Зак Галифианакис. В общем, при просмотре «Бёрдмена», смех сквозь слезы обеспечен.
Эмма Стоун так хотела сняться в картине, что снималась в «Бёрдмэне» во время перерыва в съемках фильма «Новый Человек-паук: Высокое напряжение» (2014), которые также проходили в Нью-Йорке. Из-за необычного стиля съемок с длинными дублями, Эдвард Нортон и Майкл Китон решили вести подсчет количества ошибок, совершаемых актерами. Больше всех ошибок сделала Эмма Стоун, а меньше всех — Зак Галифианакис. Большая часть съемок проходила в театре Сент-Джеймс на Бродвее — Майклу Китону и остальным актерам пришлось приспосабливаться к строгому стилю съемок Алехандро Гонсалеса Иньярриту, так как от них требовалось заучивать до 15 страниц диалогов для сцен, которые снимались одним дублем. Майкл Китон сказал, что личность Риггана является наиболее несхожей с ним самим по сравнению со всеми остальными его ролями.
По словам Алехандро Гонсалеса Иньярриту, он обедал с режиссером Майком Николсом в Нью-Йорке за две недели до начала съемок в фильме. Иньярриту рассказал Николсу о его плане снимать фильм одним длинным дублем. Николс предсказал, что это будет катастрофа, потому что отсутствие возможности использовать различные дубли при монтаже будет препятствовать созданию комедии. Иньярриту сказал, что встреча не остановила его от задуманного, а наоборот помогла в понимании сложности того, что он собирался сделать. Благодаря тому, что весь фильм был тщательно отрепетирован и снят последовательно, процесс монтажа занял всего две недели. Музыкальное сопровождение фильма композитора Антонио Санчеса, исполненное практически полностью на ударных инструментах, было дисквалифицировано из номинации на премию «Оскар».
Стоимость просмотра «Бердмена» на IVI.ru составляет 350 рублей. С одной стороны – это может показаться дорого за просмотр фильма в онлайн-кинотеатре». Однако, повторимся, что других способов посмотреть это кино легально попросту нет. Это эксклюзив портала «Иви». Напоследок, расскажем еще один занимательный факт о фильме. Сцена, где Ригган проходит через Таймс-сквер в одном нижнем белье, была снята за 4 дубля, начались съемки вечером в 8.30. В более раннее время был неподходящий свет, в более позднее время толпа начинала бы расходиться. Съемочная группа — минимальная, чтобы не привлекать к себе лишнего внимания. Перемещение Китона сопровождалось только 4 людьми: оператором Любецки, фокус-пуллером, бум-оператором и техником цифровой визуализации. Восемь помощников производства работали над контролем толпы. Иньярриту был неподалеку; первые два дубля он снимал Китона на смартфон. Записанное им видео использовано в следующей сцене, когда Эмма Стоун смотрела происшествие на смартфоне через Youtube. Чтобы отвлечь внимание от камеры, Иньярриту нанял группу уличных барабанщиков, которые танцевали и играли, привлекая внимание туристов на площади.
На закуску мы оставили рассказ о весенней комедии «С восьмым марта, мужчины!», вышедшей в прокат в предыдущем году, аккурат под праздник всех девушек и женщин. Это российско-белорусская кинокомедия 2014 года режиссёра Артёма Аксёненко, премьера состоялась 6 марта 2014 года. Главные роли в ней исполнили Мария Берсенева, Максим Виторган и Светлана Иванова, а на втором плане замечены Михаил Башкатов, Вера Алентова, Константин Лавиш и даже Ксения Бородина. Примечательно, что фильм пользовался довольно большим зрительским успехом. В России его посмотрели почти 400 тысяч зрителей, а в Украине – почти 100 тысяч. Тем не менее, зрительской любви картина не получила: средний рейтинг на «Кинопоиске» – всего 5,1 балл из десяти возможных.
Остроумная комедия Артема Аксененко, режиссера таких фильмов, как «С новым годом, мамы!», «Друзья друзей» и «Мужчина с гарантией». Сюжет фильма рассказывает про меркантильную красотку Анну, которая пробивается в жизни любыми средствами, однако в определенный момент получает в дар необычную способность. У Анни прямо-таки говорящая фамилия – Беркутова. Она, словно хищная птица, охотится на деньги и на мужчин. Только вместо когтей у красавицы – глубокое декольте, а вместо крыльев – красивые стройные ножки. У Анны в жизни все прекрасно: она ведет важный проект в Сколково и собирается замуж за богатого иностранца. Но внезапно, проект перехватывают конкуренты, а жених исчезает в неизвестном направлении. К тому же героиня внезапно узнает, что может слышать мысли мужчин. Эта способность сначала доводит её до отчаяния, а затем открывает широкие возможности…
Бюджет у картины довольно высокий – чуть более трех миллионов долларов. В Российском прокате лента так и не смогла окупить себя – она собрала два с половиной миллиона. Пошлых шуток в картине совсем не так много, как могло бы было быть – фильм можно смотреть детям от двенадцати лет. Примечательно, что фильм доступен для легального просмотра на ivi.ru абсолютно бесплатно – разве что перед началом трансляции картины придется посмотреть пару-тройку рекламных роликов.
Вернуться назад
