Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457
HDTV.ru > Это интересно > Обзор приложения «ТелеДом» для Dune HD
Обзор приложения «ТелеДом» для Dune HD16.02.2015 |
В фирменном магазине приложений Dune Store для одноименных мультимедийных приставок появилось приложение, позволяющее смотреть через Интернет канал «ТЕЛЕДОМ». Распространяется это приложение абсолютно бесплатно, как и все программы в виртуальном магазине. Абонентской платы тоже, разумеется, нет. Несложно догадаться из названия, что «ТелеДом» – это канал, рассчитанный на всех членов семьи, от мала до велика. Его миссия заключается в формировании позитивного мышления и стремления к развитию в любом возрасте, создание ощущения радости и гармонии жизни. На телеканале не транслируются передачи, фильмы и сериалы, связанные с насилием, негативом и пропагандированием нездорового образа жизни. Напротив, программы, транслируемые по «ТелеДому», направлены на поддержание и укрепление семейных ценностей. Канал начал свое вещание в ноябре 2012-го года. Территория вещания распростирается по всей России, однако наибольшее количество зрителей «ТелеДома» сосредоточено в Северо-Западном и Центральном федеральных округах. Примечательно, что формат трансляции телеканала – Full HD, и он был таковым с самого старта вещания. Канал производит более трех тысяч часов собственного контента в формате высокой четкости в год и ежедневно транслирует более 1,5 часов передач для детей в день. Разумеется, приложение для приставки Dune HD умеет показывать программу передач с описанием транслируемого контента. Помимо прочего, пользователь сам может выбрать качество трансляции – низкое, среднее или высокое, буквально для любой скорости Интернет-подключения. К качеству приема сигнала у нас замечаний нет – трансляция идет на прямую с серверов «ТелеДома». Пользоваться приложением очень удобно – нажал, и сразу смотришь вещание канала. Ничего дополнительно активировать, нигде кликать не нужно. Просто и удобно. Для справки. Телеканал «ТелеДом» является обладателем престижной профессиональной премии в области кабельного и цифрового телевидения «Золотой Луч 2014» в номинации «Лучший развлекательный телеканал России». Канал официально зарегистрирован как Средство Массовой Информации. «ТелеДом» позиционируется как семейное телевидение в формате высокого разрешения Full HD из Санкт-Петербурга пронизанное духом и культурой Северной столицы. С момента первого выхода в эфир в 2012 году канал «ТелеДом» ежедневно 24 часа в сутки представляет свои зрителям программы разных жанров: ток-шоу, художественные и документальные фильмы, концерты и спектакли театров Санкт-Петербурга. При этом большинство программ на канале создано на собственной студии в Санкт-Петербурге. Кроме того, канал не только информационно поддерживает и освещает значимые культурные события, проходящие в Санкт-Петербурге, но и создаёт уникальные телевизионные проекты, направленные на повышение уровня культуры телезрителей, популяризации Санкт-Петербурга в регионах нашей страны. Социально-культурная направленность контента, отсутствие насилия, а также целевое вещание для детской аудитории в рамках детского канала «Апельсин», делает телеканал не просто интересным для разновозрастной семейной аудитории, но и активным проводником истинных культурных ценностей. Напоследок отметим, что деятельность канала «ТелеДом» получила позитивную оценку профильных исполнительных органов государственной власти Санкт-Петербурга: Комитета по культуре и Комитета по социальной политике Санкт-Петербурга. Канал «ТелеДом» бесплатно распространяется в кабельных сетях Санкт-Петербурга и Москвы, городах-миллионниках, а также более чем в ста городах России, по средствам IPTV и Smart TV, а также через Интернет. Впрочем, объективно говоря, самый удобный способ смотреть «ТелеДом» – с помощью приставки Dune HD. Вернуться назад |
