Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Обзор приложения MegaFon.TV для Dune HD
HDTV.ru > Это интересно > Обзор приложения MegaFon.TV для Dune HD
15.12.2014
В последние годы все больше и больше людей отказываются от просмотра эфирных телеканалов в пользу поиска и воспроизведения отдельных интересующих передач посредством сети Интренет. Зачем дожидаться определенного времени, терпеть рекламные паузы и весьма низкое качество картинки, когда можно посмотреть интересующую программу прямо здесь и сейчас в качестве HD на каком-нибудь онлайн-кинотеатре? Звучит вполне логично. Телевидение уже давно бы перестало быть таким популярным, если бы не эксклюзивный контент, которым не могут похвастаться различные Интернет-ресурсы. Вероятно, именно поэтому компании MegaFon и «МегаЛабс» попытались объединить все преимущества Интернет-телеканалов и эфирного вещания в одноименном сервисе MegaFon.TV. Получилось очень интересно и необычно. Аналогов подобному сервису мы еще не видели.
Несложно догадаться, что MefaFon.TV – это кросс-платформенный сервис, предоставляющий доступ к эфирным и Интернет-телеканалам. Им можно пользоваться не только с помощью медиаплееров Dune HD. Сервис также доступен в Smart TV, на компьютере через сайт, а также на мобильных устройствах с помощью фирменного приложения для Android и iOS.
Ко всем гаджетам привязывается единственный аккаунт «Мегафона», то есть, доплачивать за подключение дополнительных устройств не придется. Очень удобно. Слоган у приложения следующий: «Десятки каналов, фильмы, сериалы и другой развлекательный видеоконтент в высоком качестве станут доступны Вам с услугой Медиапортал MegaFon.TV! Подключив услугу, Вы сможете смотреть любимые передачи дома, на работе, в путешествии — везде, где есть компьютер или мобильное устройство и доступ в Интернет».
Перед тем, как начать пользоваться сервисом, необходимо пройти несложный процесс регистрации. Для этого надо зайти на официальный сайт сервиса и нажать сооветствующую кнопку в правом верхнем углу. Появится небольшое всплывающее окно, в котором необходимо ввести номер мобильного телефона. После этого на него придет сообщение о подключенной услуге и пароль для доступа к сервису.
После ввода номера телефона и пароля, пользователь попадает в основное меню приложения. Оно сделано очень просто, в нем всего три раздела: «Каналы», «Настройки» и «Личный кабинет». Несложно догадаться, что для начала просмотра необходимо зайти в первую вкладку. В нее помещаются все доступные каналы.
Для доступа ко вкладкам настроек и пользовательского профиля необходимо ввести специальный пин-код, который приходит в регистрационном SMS-сообщении. По-умолчанию он следующий: «0000», в личном кабинете его можно изменить.
Меню настроек небольшое. В нем можно установить начальный битрейт вещания HLS и время буферизации. Также здесь можно проверить скорость подключения к сети. Yа один абонентский номер можно подключить до 5 устройств (в том числе компьютеры, ТВ-приставки, смартфоны или планшеты). Для управления устройствами зайдите в «Личный кабинет» на сайте сервиса в раздел «Устройства».
В личном кабинете пользователь может выбрать, какие пакеты каналов он хочет смотреть. Пакеты перечислены список, с указанием названия, стоимости подписки, стоимости подключения, а также текущего баланса пользователя.
Подключить пакет очень просто. Достаточно нажать на название интересующего каталога каналов, прочитать информцию о нем и нажать «подключить» или «отмена». Абонентская плата списывается в течение 24-х часов после подключения любого пакета. Далее списание абонентской платы происходит один раз в сутки. Если абонент отключает и снова подключает любой из пакетов в течение дня, абонентская плата будет списана повторно. После подключения или отключения какого-либо пакета приходит SMS-подтверждение на сопряженный номер.
На предлагаемых сервисом пакетах следует остановиться подробнее. Все в сервисе предсмотрено 11 тематических пакетов телеканалов. Расскажем о них подробно.
- Основной (8 рублей в сутки): 78 профильных телеканалов о новостях, развлечениях, спорте, моде, мультфильмах, музыке, кино и прочем;
- Пакет HD (6 рублей в сутки, 15 каналов): Спорт 1 HD, Eurosport HD, Travel and Adventure HD, Nickelodeon HD, MTV Live HD, Россия HD, Discovery Science HD, TLC HD, КХЛ HD, MTV HD, Outdoor channel HD, My Zen TV, Discovery channel HD, Animal Planet HD, RTG HD, Travel channel HD;
- Стартовый (1 рубль в сутки, 30 каналов): Первый канал, Россия — 1, Россия — 2, НТВ, Россия — 24, Россия — Культура, Петербург — 5 канал, Карусель, ТВ ЦЕНТР, ОТР, Luxury World, Радость моя, «MUSICBOX», Сарафан, MTV Hits, MTV Dance, MTV Rocks, СТРАНА, Мужской, Загородная жизнь, Юмор Box, A-ONE, Style — TV, France 24, Про Бизнес ТВ, Мать и Дитя, Bridge TV, 8 канал, Мир, Lifenews HD;
- Спортивный (2 рубля в сутки, 6 каналов): Eurosport 2 Live, Общероссийский канал «Спорт», Eurosport News, Драйв, Extreme Sports, Nautical Channel;
- Познавательный (3 рубля в сутки, 5 каналов): Наука, ID Investigation Discovery, Discovery World Channel, 24 Техно, 24 Док;
- Кино (3 рубля в сутки, 6 каналов): Sony Sci-Fi, E! Entertainment, Русский Иллюзион, Иллюзион+, Еврокино, ТВ — 21 М (TV ХХI век);
- Международный (1 рубль в сутки, 5 каналов): France 24 («Франс 24»), ТНВ-Планета, ТМТ Майдан, Deutsche Welle, TV5 Monde;
- Детский (1 рубль в сутки, 4 канала): Baby TV («Дитя ТВ»), Детский мир, Радость моя, JimJam;
- 18+ (7 рублей в сутки, 2 канала): PlayBoy TV, Candy;
- CANDYMAN (5 рублей в сутки, 1 канал);
- AMEDIA PREMIUM HD (4 рубля в сутки, 1 канал).
Всего «Мегафон.ТВ» предлагает зрителям более 120 различных телеканалов, скомбинированных в различных тематических пакетах.
Список доступных для просмотра телеканалов собран в отдельном меню. Каналы разбиты по категориям, также их можно вывести единым общим списком.
Качество трансляции зависит от скорости Интернет-соединения. Каких-либо глюков и неприятных подвисаний за время тестирования замечено не было. Для каждого телеканала доступна подробная интерактивная программ передач с кратким описанием. Очень удобная и наглядная.
Наш тест наглядно показал, что утилита MegaFon.TV для медиаплееров Dune HD – интересное и далеко не обычное решение. Создатели смогли вполне успешно объеденить Интернет-вещание и телевидение в одно целое, и получилось действительно здорово. Благодаря автоматической подстройке сигнала, приложение работает действительно стабильно быстро, без пауз и «подергиваний» изображения.
Обилие различных пакетов и телеканалов, невысокая стоимость абонентской платы, кросс-платформенность – все это делает MegaFon.TV, по-сути, уникальным предложением на рынке. У сервиса очень богатая функциональность, которая предоставляется пользователям за относительно разумные деньги. Удобное приложение, красивый и понятный интерфейс, видео по запросу плюс информативная программа передач – неполный список достоинств «Мегафон.ТВ».
Интересное замечание на последок, которому очень обрадауются абоненты «Мегафона». С 10-го декабря 2013 года мобильное приложение услуги работает в сетях 3G и 4G+. При нахождении в зоне действия мобильной сети «МегаФон» плата за трафик при использовании приложения не взимается – только за подписку на сервис. Разумеется, чтобы пользоваться услугой «Мегафон.ТВ» необязательно быть абонентом одноименного оператора сотовой связи, однако, в таком случае придется платить и за передачу данных в мобильных сетях. Впрочем, этого можно избежать, например, подключившись к сети Wi-Fi.
Вернуться назад
