Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Плазменные телевизоры Panasonic 2011 с ценами
HDTV.ru > Это интересно > Плазменные телевизоры Panasonic 2011 с ценами
19.03.2011
В начале года Panasonic представил новые модели плазменных и жидкокристаллических телевизоров Viera 2011. Представителями нового модельного ряда плазменных HDTV Panasonic будут VT30, GT30, ST30, G30 и S30, большая часть новых моделей оснащаются усовершенствованной плазменной панелью Infinite Black 2 и поддерживают технологию 3D. В этой статье представлен общий обзор европейского модельного ряда телевизоров Panasonic Viera 2011 года с рекомендованными производителем ценами, а также ответы специалистов компании на вопросы покупателей.
Panasonic VIERA 2011 в общих чертах
В 2011 году Panasonic использует в своих телевизорах новый дизайн. Рамка вокруг экрана стала уже, а корпус телевизора тоньше. Флагманские модели VT30 будут выделяться абсолютно плоской лицевой поверхностью из единого листа стекла.
Panasonic говорит, что при разработке моделей 2011 года были выбраны три основных приоритета: качество изображения, технология Smart Viera и внешний дизайн.
Panasonic обещает повышенное качество изображения, как в режиме стандартного просмотра, так и в режиме 3D. Для телевизоров 2011 года были разработаны две новых плазменных панели с уровнем контрастности Infinite Black 2 и Infinite Black 2 Pro. Они включают такие усовершенствования, как более глубокий уровень черного цвета, еще более сниженные перекрестные помехи в режиме 3D и повышенный световой поток при одновременном снижении энергопотребления.
Panasonic также заявляет, что во всех full HD плазменных телевизорах 2011 года будет использоваться новое, более быстрое люминофорное покрытие плазменных ячеек, впервые примененное в прошлом году лишь на флагманских моделях VT20/VT25. В большинстве моделей имеется режим повышенной точности воспроизведения THX. Читайте дальше, чтобы узнать больше о новых панелях Panasonic.
Panasonic по-прежнему уделяет особое внимание технологии 3D воспроизведения, и с новыми более легкими 3D очками обещаются еще более восхитительные впечатления от просмотра, функция конверсии 2D/3D позволяет смотреть стандартное изображение в объемном представлении. Компания добавила в режим 3D воспроизведения несколько усовершенствований, включая систему видеообработки, которая совершенствует 3D эффект и снижает перекрестные помехи. Panasonic также утверждает, что увеличенный световой поток помогает создавать захватывающее воображение объемное изображение.
Panasonic представил в этом году новую систему интернет сервисов, названную Viera Connect. С этой новой интернет платформы Panasonic будет предлагать видео по запросу, доступ к YouTube, мини-игры и другой локализованный для отдельных стран контент. Игры будут предоставляться Panasonic совместно с партнером компанией Gameloft в виде распределенного по интернету сервиса (cloud service). Новые приложения можно скачивать как в виде платных, так и бесплатных приложений.
Универсальная система Smart Viera обеспечивает кроме того и доступ к социальным, мультимедийным сервисам, например, Facebook. Panasonic также упоминает сервис Ustream, который позволяет пользователям хранить свои медиафайлы в интернете, а при необходимости смотреть на телевизорах Panasonic с поддержкой Viera Connect.
Большинство моделей оснащаются такими функциями, как поддержка стандарта DLNA, HDTV из верхнего ценового диапазона имеют встроенный беспроводной интерфейс Wi-Fi. Европейские модели будут выделяться такими дополнительными мультимедийными функциями, как запись через порт USB на внешние HDD.
Состав плазменного модельного ряда Panasonic Viera 2011
Ниже представлены особенности телевизоров из плазменных серий Panasonic 2011 года. В серии C3 представлены модели начального уровня, далее по возрастающей следуют более совершенные и дорогие серии.
Серия C3
Плазменные телевизоры начального уровня из серии Panasonic C3 поддерживают основные фирменные технологии, обеспечивают контрастность 2 000000:1, заявленное время отклика 0,001 мс.
Panasonic C3
Особенности плазменных телевизоров Panasonic С3:
Качество изображения:
• Панель Progressive HD
• Разрешение 720p
• Технология 600 Гц Sub-field Drive
Сетевые возможности:
• Поддержка DLNA
• VIERA Image Viewer: фото/видео/музыка
• Функция VIERA Link
• Wi-Fi Ready
• Визуальный интерфейс VIERA Tools
• Режим Game
• 2 входа HDMI
Звук:
• 2х10 ватт
• V-Audio
• Dolby Digital Plus
Прочее:
• Не используются ртуть и свинец
• Срок службы панели до 100 000 часов
• Режим энергосбережения
Плазменные телевизоры Panasonic из серии X3 будут доступны с апреля: TX-P42X3 (670 евро), TX-P50X3 (930 евро).
Серия S30
Плазменные телевизоры из серии Panasonic S30 относятся к недорогим и достаточно оснащенным моделям компании. Усовершенствованная технология Intelligent Frame Creation Pro обеспечивает более четкое воспроизведение динамичных сцен. Для Panasonic S30 заявленная контрастность составляет 2 000000:1, а время отклика 0,001 мс.
Panasonic S30
Особенности плазменных телевизоров Panasonic S30:
• Панель G14 Progressive Full-HD
• VIERA Connect
• Поддержка DLNA
• Wi-Fi Ready
• Режим Game
• 3 входа HDMI
Звук:
• Технология V-Audio Surround
• 2х10 ватт
Прочее:
Плазменные телевизоры Panasonic из серии S30 будут доступны с марта/апреля лишь с одним размером экрана 42 дюйма: TX-P42S30 (930 евро).
Серия G30
На смену одной из наиболее популярных прошлом году серий G20 в этом году пришла G30. Плазменные телевизоры из серии Panasonic G30 относятся к среднему ценовому диапазону, обладают достаточно всеобъемлющими функциональными возможностями, поддерживают широкий диапазон технологий, за исключением 3D. Для Panasonic G30 заявленная контрастность составляет 5 000000:1, а время отклика 0,001 мс.
Panasonic G30
Особенности плазменных телевизоров Panasonic G30:
• Плазменная панель Infinite Black 2
• Сертификация THX и калибровка ISFccc
• VIERA Connect
• Поддержка DLNA
• USB для подключения беспроводного адаптера, клавиатуры и HDD
• Wi-Fi Ready
• Режим Game
• 4 входа HDMI
Звук:
• 2х10 ватт
Прочее:
Panasonic G30
Плазменные телевизоры Panasonic из серии G30 будут доступны с марта/апреля: TX-P42G30 (1200 евро), TX-P46G30 (1475 евро), TX-P50G30 (1730 евро).
Серия ST30
Плазменные телевизоры из серии Panasonic SТ30 относятся к недорогим моделям с функцией 3D и достаточно оснащены фирменными технологиями видеообработки. Для Panasonic SТ30 заявленная контрастность составляет 5 000000:1, а время отклика 0,001 мс.
Panasonic SТ30
Особенности плазменных телевизоров Panasonic ST30:
• FULL HD 3D
• VIERA Connect
• Поддержка DLNA
• Wi-Fi Ready
• Режим Game
• 3 входа HDMI
Звук:
• 2х10 ватт
Прочее:
Плазменные телевизоры Panasonic из серии ST30 будут доступны с апреля: TX-P42ST30 (1475 евро), TX-P46ST30 (1730 евро), TX-P50ST30 (2000 евро).
Серия GT30
На смену одной из наиболее популярных прошлом году серий G20 в этом году пришла GT30 с поддержкой 3D.
Panasonic GT30
Особенности плазменных телевизоров Panasonic GT30:
• Flush дизайн
• FULL HD 3D
• VIERA Connect
• Поддержка DLNA
• Встроенный Wi-Fi
• Режим Game
• 4 входа HDMI
• Вертикальная ориентация разъемов
• Вход ПК
Звук:
• 2х10 ватт
Прочее:
Panasonic GT30
Плазменные телевизоры Panasonic из серии GT30 будут доступны с апреля: TX-P42GT30 (1730 евро), TX-P46GT30 (2000 евро), TX-P50GT30 (2275 евро).
Серия VT30
Телевизоры флагманской серии VT30 выделяются новым дизайном с плоской лицевой панелью из сплошного стекла и поддержкой всех современных фирменных технологий.
Panasonic VT30
Особенности плазменных телевизоров Panasonic VT30:
• Дизайн сплошной стеклянной панели
• FULL HD 3D (в комплекте 3D очки – 2 шт.)
• Плазменная панель Infinite Black Pro 2
• Экранный фильтр High contrast Pro
• VIERA Connect
• Поддержка DLNA
• USB для подключения беспроводного адаптора, клавиатуры и HDD
• Встроенный Wi-Fi
• Режим Game
• 4 входа HDMI
• Вход ПК
Звук:
• Встроенный сабвуфер
• Технология V-Audio ProSurround
• 2х6 ватт + 10 ватт
Прочее:
Panasonic VT30
Плазменные телевизоры Panasonic из серии VT30 будут доступны с апреля/мая: TX-P42VT30 (2000 евро), TX-P50VT30 (2675 евро), TX-P55VT30 (3350 евро) и TX-P65VT30, стоимость которого пока неизвестна.
Общие таблицы по технологиям и ценам
По этой таблице можно судить о поддержке новыми моделями отдельных технологий Panasonic:
В этой таблице представлены стартовые рекомендованные производителем цены для европейского рынка в евро:
Ответы специалистов компании на вопросы покупателей
Ниже представлены наиболее часто задаваемые покупателями вопросы, ответить на которые постарались специалисты компании в ходе презентации европейского модельного ряда телевизоров Panasonic 2011 года.
Какими 3D очками будут комплектоваться новые 3D телевизоры?
Такими, какие были впервые представлены на выставке IFA 2010 в Берлине (ими комплектовались модели GT20/GT25).
В прошлом году Panasonic планировал представить LCD телевизоры с системой локального затемнения на основе LED подсветки, однако затем один из представителей компании заявил, что на рынке нет особой потребности в телевизорах с прямой LED подсветкой. Так ли это?
Исходя из рыночной ситуации Panasonic не видит большого потенциала для LED моделей с локальным затемнением.
Будет ли продаваться в Европе 42 и 46 дюймовая версия VT30?
Будут только модели с экранами 42 и 50 дюймов.
Будет ли Panasonic продавать телевизоры с двумя ТВ тюнерами, чтобы можно было смотреть одну телепередачу, одновременно записывая другую?
В моделях 2011 года двух тюнеров не будет.
Будет ли в этом году компания продавать жидкокристаллические телевизоры с размером экрана по диагонали 46 дюймов?
Максимальный размер экрана для LCD моделей этого года 42 дюйма, 46 дюймовой модели не будет.
В чем основное отличие моделей S30 от S20?
Модели S30 оснащаются панелями с более быстрым люминофорным покрытием плазменных ячеек.
Не собирается компания представить в этом году элитные модели, подобные сериям ZT30 или VX300?
Планов по производству новых моделей в сериях Z или VX на данный момент нет.
Что можете сказать о патентах Pioneer Kuro в моделях Viera 2011 года?
Panasonic ничего не сказал об использовании патентов Pioneer Kuro, но отметил безусловный вклад в разработку новых моделей принятых на работу специалистов.
Когда можно будет воспользоваться планшетом Viera (Viera tablet) и будет ли он совместим с моделями 2010 года?
В настоящее время это еще опытный образец и нет планов по представлению реальной модели.
Будут ли продаваться в 2011 году модели без 3D?
Да, все модели без буквы «Т» в маркировке не являются 3D HDTV.
Будет ли в новых телевизорах Panasonic применена технология излучающих кристаллов Pioneer CEL (Crystal Emissive Layer)?
Panasonic не сделала никаких официальных заявлений о патентах Pioneer Kuro, но отметил несомненный вклад принятых на работу в компанию сотрудников.
Каковы в действительности контрастность и уровень черного цвета у моделей серии VT30?
Panаsonic представляет только определенные заданием на проектирование параметры, реальные данные появятся уже вскоре по результатам независимых тестов.
Будут ли новые плазмы Panasonic соответствовать или может быть превосходить возможности Pioneer G9 Kuro?
Требуется дополнительное тестирование
В плазменных телевизорах компании 2010 отмечался ряд проблем, решены ли они в моделях 2011 года?
Технические параметры новых телевизоров улучшены, насколько, это можно будет узнать из независимых обзоров и тестов.
Сейчас при записи на жесткий диск необходимо отформатировать его в соответствии с фирменным форматом Panasonic, после чего его нельзя использовать ни с какими другими устройствами, кроме телевизора. Будет ли более открытый способ записи с телевизора?
Пока нет планов по изменению этой системы, также как и у других производителей, это вопрос, касающийся приобретения лицензий.
Когда появится LCD телевизор Panasonic с прямой LED подсветкой?
Panasonic заявляет, что они изучают ситуацию на рынке.
Плазменные телевизоры новых серий C и X сделаны на основе предыдущего поколения плазменных панелей NeoPDP?
Не совсем так. Используются новые панели, но с применением некоторых принципов использовавшихся в NeoPDP.
Улучшена ли система IFC? Если да, как это в целом сказалось на видеообработке?
В новых моделях улучшена система видеообработки, особенно для 3D. Подробности будут представлены позднее.
Будет ли поддержка стандарта DVB-T2?
Да, в более дорогих моделях.
Какова входная задержка у новых моделей?
Точные значения будут получены после тестирования, Panasonic заявляет, что они зависят от активации систем видеообработки телевизора.
Есть ли в моделях 2011 года возможность записи аналоговых сигналов через SCART?
Нет.
Какие модели наиболее подходят для игр?
Все Full HD модели этого года оснащены плазменными панелями с быстрым люминофором. Точные значения задержек будут получены после тестирований.
Каковы планы Panasonic относительно OLED технологии?
В настоящее время никаких официальных нет.
Будет ли в этом году производиться серия V (со всеми технологиями серии VT, но без поддержки 3D), если да, с какими размерами экрана?
Нет, будет только серия VT.
Насколько велики усовершенствования в 3D режиме для моделей 2011 года, относительно моделей 2010 года? Небольшая разница или заметные улучшения?
Panasonic утверждает, что они использовали ряд усовершенствований, позволивших повысить качество 3D изображения. Это, конечно, приятный ответ, но придется подождать, чтобы узнать конкретные результаты.
Будет ли в моделях серии VT30 применена система решения проблема 50 Гц, уже использованная в профессиональной серии VX?
На данный момент неизвестно.
Что известно о решении проблемы остаточного изображения?
Panasonic заявляет, что новое фосфорное покрытие еще более снижает эффект остаточного изображения, но насколько станет ясно позднее.
Будет ли 58 дюймовая плазма в серии VT30?
Нет, 58 дюймовой модели не будет.
Есть заявления о глубоком уровне черного цвета у жидкокристаллических телевизоров серии DT30, как удалось его достичь?
Глубокие оттенки черного цвета на LCD панели с боковой системой LED подсветки достигаются за счет использования системы локального затемнения.
(Прим. Вместе с тем, используемые в телевизорах Panasonic панели типа IPS, имея определенный ряд преимуществ, уступают по воспроизведению черного некоторым системам на сегодняшнем рынке, особенно имеющим подсветку в виде полного массива LED источников с локальным затемнением.)
Какая из 32 дюймовых моделей LED HDTV без 3D/Internet лучше подойдет для видеоигр?
Трудно сказать. Об этом можно будет судить лишь поиграв на новых моделях и сняв конкретные характеристики.
Вернуться назад
