Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/engine.php on line 155 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 101 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 236 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 241 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 374 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /var/www/hdtv.ru/engine/modules/show.full.php on line 457 Телевизоры Sony Bravia 2011 (с ценами)
HDTV.ru > Это интересно > Телевизоры Sony Bravia 2011 (с ценами)
29.01.2011
Компания Sony представила в конце января европейский вариант модельного ряда телевизоров Sony Bravia 2011 года. Функциональные возможности телевизоров значительно расширились, а использование более совершенных технологий видеообработки должно значительно повысить качество изображения. В HDTV компании этого года появилась такая функциональная возможность как запись с телевизора через порт USB, в моделях высшего класса повышена до 800 Гц частота обновления изображения, что совместно с технологией LED подсветки с местным затемнением отразится на качественном уровне изображения. Кроме того Sony увеличила количество моделей в привлекательном монолитном дизайне.
Особенности телевизоров Sony 2011
Ряд новых интересных моделей LCD телевизоров Sony Bravia появится в продаже уже в начале года.
В телевизорах 2011 года компания уделяет основное внимание качеству изображения и оснащению их функцией 3D, а также наделению функциями записи через USB порт, использованию системы видеосвязи Skype и встроенного веб-браузера Opera.
Большая часть моделей 2011 года основана на модельной концепции, сформированной в прошлом году. Sony продолжает использовать изысканный монолитный дизайн, с серой подставкой в виде металлического бруска в отдельных моделях. Большинство телевизоров выполнены в тонком корпусе с узким обрамлением экрана.
Новинкой является функция записи с телевизора через USB порт. Как правило, для записи можно использовать внешний жесткий диск или флеш-накопитель. Автоматизировать процесс записи поможет телевизионный таймер.
Sony продолжает расширять перечень доступных через интернет потоковых видео сервисов, а большинство моделей среднего и высшего класса будут иметь еще и встроенный веб-браузер Opera, правда с ограниченными возможностями (например, нет поддержки флэш-видео). Sony также последовала примеру конкурентов и начинает оснащать отдельные модели системой видеосвязи через интернет – Skype. В 2011 году планируется расширение видеосервиса по требованию Sony Qriosity, он станет доступным практически во всей Европе.
И, естественно, продолжается активное предложение покупателям 3D технологии в приставках PlayStation 3 и телевизорах Bravia, 3D по-прежнему является одной любимых тем для маркетолов компании. Более того Sony собирается в 2011 году расширить свое семейство 3D телевизоров за счет более дешевого модельного ряда Essential.
Sony также обещает представить в 2011 году несколько классных 3D игр для PS3 и такие новые 3D фильмы, как Men in Black 3, TinTin, Spiderman, Green Hornet и The Smurfs.
Новая система видеообработки X-Reality PRO состоит из двухчипового цифрового видеопроцессор, который оптимизирует изображение высокого и стандартного разрешения, более эффективно обрабатывает сжатое HD и SD видео, а также сигналы от других источников, включая видео низкого разрешения из интернет. Некоторые более дешевые модели будут оснащаться упрощенной системой видеообработки – X-Reality.
Наилучшим качеством изображения обладают модели из семейства Cinematic, которое в 2011 году пополнится тремя сериями HX920, HX820 и HX720. Производство самых классных моделей 2010 года из семейства Signature, маркировавшихся буквами LX, в 2011 году будет прекращено.
Кроме того, Sony обещает представить новые модели в семействе Presence (маркирующиеся буквами NX) с акцентом на улучшенный дизайн. Наконец, Sony выпустит ряд новых телевизоров в семействе Essential, под обозначениями EX, с упором на наиболее важные для среднестатического пользователя функции. Самые дешевые 3D телевизоры Sony в 2011 году будут частью семейства Essential в серии EX720.
Семейство Cinematic
Телевизоры семейства Cinematic представляют превосходное качество изображения и такие современные функции, как кадровая технология 800 Гц, светодиодная подсветка с локальным затемнением и 3D режим. Если вы не признаете компромиссных решений в отношении качества изображения и хотите получить лучший из телевизоров Sony, тогда выбирайте модели из серии Sony Cinematic.
Cinematic HX920
Новая флагманская модель Sony HX920 оснащена 800 Гц системой кадровой развертки и LED подсветкой с локальным затемнением, что улучшает контрастность и повышает уровень черного.
Sony HX920
Серия HX920 включает технологию 3D и LCD панель Sony OptiContrast.
Особенности моделей Sony Cinematic HX920:
• LED подсветка с локальным затемнением
• LCD панель OptiContrast и монолитный дизайн
• Функция 3D и конвертор 2D/3D
• Встроенный интерфейс Wi-Fi (802.11n)
• Система видеосвязи Skype и DLNA функциональность
• BRAVIA Видео Интернет и сервис Qriocity
• Видеопроцессор X-Reality Pro
• Запись через порт USB
• Технология MotionFlow XR 800 (800 Гц)
Sony HX920
Модели Sony HX920 будут доступны с июня 2011 года с экранами 46, 55 и 65 дюймов под обозначениями 46HX920, 55HX920 и 65HX920 (с сентября). Сведения о ценах см. в таблице ниже.
Cinematic HX820
Уровнем ниже находится серия HX820 с MotionFlow 400 вместо 800. Телевизоры серии HX820 также оснащаются новым видеопроцессором X-Reality Pro и функцией 3D, но располагают только обычной боковой LED подсветкой.
Sony HX820
Особенности моделей Sony Cinematic HX820:
• Динамическая боковая LED подсветка
• BRAVIA Видео Интернет и встроенный веб-браузер Opera
• Технология MotionFlow XR 400
Модели Sony HX820 будут доступны с июня 2011 года с экранами 46 и 55 дюймов под обозначениями 46HX820 и 55HX820. Сведения о ценах см. в таблице ниже.
Cinematic HX720
Модели из семейства Cinematic HX720 не обладают монолитным дизайном, но вместо этого имеют LCD панель Deep Black, оснащены боковой LED подсветкой и функцией 3D.
Sony HX720
Особенности моделей Sony Cinematic HX720:
• LCD панель Deep Black
Модели Sony HX720 будут доступны с июня 2011 года с экранами 40 и 46 дюймов под обозначениями 40HX720 и 46HX720. Сведения о ценах см. в таблице ниже.
Семейство Presence
Телевизоры семейства Presence выделяются элегантным дизайном, возможностью подключения к интернет и домашней медиа сети. Для обозначения моделей семейства используются буквы NX.
Presence NX720
Cегодня среди HDTV семейства Presence 2011 года имеется пока единственная серия NX720, которая заменяет прошлогодние NX710 и NX810. Телевизоры приходят в монолитном дизайне и со сверхпрочным стеклом Gorilla поверх LCD панели, оснащены боковой LED подсветкой и функцией 3D.
Sony NX720
Особенности моделей Sony Cinematic NX720:
• LCD панель OptiContrast со стеклом Gorilla
• Технология MotionFlow XR 200 (200 Гц)
Модели Sony NX720 будут доступны с марта/апреля с экранами 40, 46, 55 и 60 дюймов под обозначениями 40NX720, 46NX720, 55NX720 и 60NX720. Сведения о ценах см. в таблице ниже.
Семейство Essential
В семейство Essential вы найдете телевизоры с акцентом на функциональную оснащенность. Это означает, что при довольно хорошем качестве изображения имеется доступ в интернет и поддерживаются разнообразные мультимедийные функции. EX720 также имеет 3D, но ни одна из моделей семейство Essential не обладает наиболее совершенными системами видеообработки, представленными в телевизорах Cinematic.
Essential EX720
В серии EX720 представлены наиболее дорогие модели семейства Essential, они поставляются с функцией 3D и боковой LED подсветкой.
Sony EX720
Особенности моделей Sony Essential EX720:
Модели Sony EX720 будут доступны с марта с экранами в 32, 37, 40, 46 и 55 дюймов под обозначениями 32EX720, 37EX720, 40EX720, 46EX720 и 55EX720. Сведения о ценах см. в таблице ниже.
Essential EX520
На уровень ниже находятся модели серии EX520, у них нет функции 3D, но есть поддержка Bravia Internet.
Sony EX520
Особенности моделей Sony Essential EX520:
Модели Sony EX520 будут доступны с марта с экранами 32, 40 и 46 дюймов под обозначениями 32EX521, 40EX521 и 46EX521. Сведения о ценах см. в таблице ниже.
Essential EX320
Модели Essential EX320 находятся на уровень ниже от EX520. Но они все же обладают возможностью записи через порт USB.
Sony EX320
Особенности моделей Sony Essential EX320:
• Разрешение Full HD
Модели Sony EX320 с экраном 24 дюйма – 24EX320 будут доступны с марта, 22 и 26 дюймовые под названиями 22EX320 и 26EX320 появятся без поддержки разрешения Full HD и без видеопроцессора X-Reality. Сведения о ценах см. в таблице ниже.
Essential СX520
В семействе Essential представлены и телевизоры на основе традиционной системы подсветки с использованием CCFL ламп, в таких сериях как CX520.
Sony CX520
Особенности моделей Sony Essential СX520:
Модели Sony СX520 появятся в марте с экранами 40 и 46 дюймов под названиями 40CX520 и 46CX520. Сведения о ценах см. в таблице ниже.
Essential BX420
Sony BX420
Особенности Sony Essential BX420:
• Два входа HDMI
Модель Sony BX420 будет доступна с мая с экраном 40 дюймов под названием 40BX420. Сведения о ценах см. в таблице ниже.
Essential BX320
Sony BX320
Особенности моделей Sony Essential BX320:
• HD Ready
• Два входа HDMI
Модели Sony BX320 будут доступны с мая с экранами 26 и 32 дюйма под названиями 26BX320 и 32BX320. Сведения о ценах см. в таблице ниже.
Стоимость телевизоров Sony Bravia 2011
Ниже представлены цены в евро на большинство моделей жидкокристаллических телевизоров Sony Bravia из модельного ряда 2011 года для европейского рынка.
Телевизоры Sony 2011, цены в евро
Ответы на вопросы, наиболее часто возникающие у покупателей телевизоров Sony
Какие форматы поддерживаются при использовании DLNA функциональности?
Телевизоры с поддержкой DLNA могут воспроизводить:
Видео: DivX, Xvid, MPEG2PS, MPEG2TS, AVCHD, MPEG4 (H264) и WMV.
Музыка: MP3, LPCM, WMA
Фото: JPEG.
Какие изменения были внесены в интернет функциональность HDTV Sony 2011 года? Когда можно ожидать появления Google TV в Европе?
Большинство новых моделей поставляются с веб-браузером Opera, но интерфейс Bravia Интернет остался прежним. Google TV пока не запланирована для представления в Европе в 2011 году. Мультимедийный сервис Qriocity должен стать доступным в большинстве европейских стран в течение этого года.
Что означает технология 800 Гц?
Частота изменения кадров 400 Гц + сканирующая подсветка.
Когда HDTV Sony будут комплектоваться более роскошным пультом дистанционного управления?
Таких планов на данный момент, но в HDTV 2011 года вы можете использовать ваш iPhone/IPod и мобильные устройства на основе операционной системы Android.
В моделях HX920 применяется система локального затемнения. Сколько зон затемнения может использоваться?
Sony пока не предоставила такой информации.
Когда новые модели начнут появляться в продаже ?
С середины марта по сентябрь. Модели высокого класса с мая/июня 2011 года.
Планирует ли Sony производить супер тонкие телевизоры?
Нет, таких планов на данный момент. Сейчас наиболее тонкие телевизоры имеют толщину 3 см, но они при этом оснащены более точной задней LED подсветкой.
Можно ли использовать в качестве пульта дистанционного управления iPhone/IPad?
Да, на большинстве моделей. Но вам необходимо подключить телевизор к домашней сети.
Какого объема жесткий диск поддерживается при подключении к порту USB?
До 2 терабайт. Sony рекомендует использовать Western Digital.
Можно ли подключить несколько USB устройств одновременно?
Нет, по одному, но телевизор может запомнить до 8.
При записи через USB используется сжатие?
Да, небольшое.
Можно ли записывать в HD разрешении?
Да, с любых тюнеров.
Возможно ли воспроизведение с жесткого диска видео, записанного ранее через порт USB?
Да.
Каковы планы Sony с внедрением видео сервиса по запросу – VOD?
Видеосервис Sony Qriocity будет доступен в большинстве европейских стран в течение этого года.
Есть ли в телевизорах Sony глянцевый/антибликовый вариант?
LCD панель OptiContrast имеет антибликовое покрытие на защитном стекле и антибликовое покрытие между панелью и стеклом. LCD панель DeepBlack имеет антибликовое покрытие только на стекле перед панелью.
Я хочу повесить телевизор на стену, как ориентированы интерфейсы на задней панели?
Большинство входов направлены на стену.
Будет ли функция видеозаписи (PVR) в европейских моделях?
Да, в большинстве моделей.
Входят ли 3D очки в комплект HX920 или продаются отдельно, как это было с HX900.
В европейские модели включены двое очков.
Какая в новых моделях входная задержка?
Она во многом зависит от системы, которая активируется. Система MotionFlow добавляет некоторое входные отставание.
Вернуться назад
